[Mapbender_dev] digitize modul: split functionality?
Christoph Baudson christoph.baudson at wheregroup.com
Tue Sep 28 09:46:50 EDT 2010
Thomas Baschetti wrote:
> Hi Christoph,
> no, i'm in the 2.6 branch. But if there is an existing solution for
> trunk it's sufficient for me.
> Which module do i have to look at?
Take a look at the following files
http/plugins/mb_digitize_geometry.js
http/plugins/mb_highlight.js
You can let these modules cooperate by using the technique explained
here [1].
Unfortunately, I don't have a demo at hand.
Christoph
[1] http://lists.osgeo.org/pipermail/mapbender_dev/2010-March/002113.html
> Thomas
> On 28.09.2010 10:04, Christoph Baudson wrote:
>> Hi Thomas,
>> are you on trunk? In trunk there is a new module that allows you to
>> digitize a geometry, and export it to GeoJSON, so you can use it for
>> other purposes.
>> There is no demo yet, but I think this does exactly what you want.
>> If interested, I can elaborate.
>> Christoph
>>> Hi,
>>> in a project i'm using the digitize-modul to do some
>>> client-side digitizing, which works really good.
>>> Now i want to select and edit some existing geometries, but without
>>> saving them back. Something like:
>>> - select an existing area via click
>>> - perform some action on this area (change geometry)
>>> - use this area to select other features (e.g. residents in a district)
>>> my problem:
>>> - Mapbender wants an transactional WFS to do this (select via wfs)
>>> - i can set nonTransactionalEditable=true to select other wfs, but these
>>>   are (of course) handled as editable, with the buttons enabled
>>> - i only want client-side editing, with no buttons to write changes
>>> back (which would fail)
>>> Is this possible with the existing sourcecode, am i missing something?
>>> If not, perhaps we should seperate the funcionalities in the next
>>> mapbender-version
>>> into strictly client-side work (digitize) and server-side (saving,
>>> updating).
>>> Thomas
INTERGEO 2010
05.-07. Oktober 2010 in Köln
Halle 11.2, Stand 2C.121
www.intergeo.de
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
