[Mapbender_dev] digitize modul: split functionality?
Thomas Baschetti info at thomas-baschetti.de
Tue Sep 28 05:05:10 EDT 2010
Hi Christoph,
no, i'm in the 2.6 branch. But if there is an existing solution for
trunk it's sufficient for me.
Which module do i have to look at?
Thomas
On 28.09.2010 10:04, Christoph Baudson wrote:
> Hi Thomas,
> are you on trunk? In trunk there is a new module that allows you to
> digitize a geometry, and export it to GeoJSON, so you can use it for
> other purposes.
> There is no demo yet, but I think this does exactly what you want.
> If interested, I can elaborate.
> Christoph
> Thomas Baschetti wrote:
>> Hi,
>> in a project i'm using the digitize-modul to do some
>> client-side digitizing, which works really good.
>> Now i want to select and edit some existing geometries, but without
>> saving them back. Something like:
>> - select an existing area via click
>> - perform some action on this area (change geometry)
>> - use this area to select other features (e.g. residents in a district)
>> my problem:
>> - Mapbender wants an transactional WFS to do this (select via wfs)
>> - i can set nonTransactionalEditable=true to select other wfs, but these
>>   are (of course) handled as editable, with the buttons enabled
>> - i only want client-side editing, with no buttons to write changes
>> back (which would fail)
>> Is this possible with the existing sourcecode, am i missing something?
>> If not, perhaps we should seperate the funcionalities in the next
>> mapbender-version
>> into strictly client-side work (digitize) and server-side (saving,
>> updating).
>> Thomas
Thomas Baschetti - Systemanalyse Geographische Informationssysteme
Hakenstraße 8D
49074 Osnabrück
Tel: 0541 25 91 90 | mobil 01577 189 25 91
E-Mail: info at thomas-baschetti.de
www.thomas-baschetti.de
Ust-IdNr.: DE264355072
More information about the Mapbender_dev mailing list
