[Mapbender_dev] digitize modul: split functionality?
Christoph Baudson
christoph.baudson at wheregroup.com
Tue Sep 28 04:04:17 EDT 2010
Hi Thomas,
are you on trunk? In trunk there is a new module that allows you to
digitize a geometry, and export it to GeoJSON, so you can use it for
other purposes.
There is no demo yet, but I think this does exactly what you want.
If interested, I can elaborate.
Christoph
Thomas Baschetti wrote:
> Hi,
> in a project i'm using the digitize-modul to do some
> client-side digitizing, which works really good.
> Now i want to select and edit some existing geometries, but without
> saving them back. Something like:
> - select an existing area via click
> - perform some action on this area (change geometry)
> - use this area to select other features (e.g. residents in a district)
> my problem:
> - Mapbender wants an transactional WFS to do this (select via wfs)
> - i can set nonTransactionalEditable=true to select other wfs, but these
> are (of course) handled as editable, with the buttons enabled
> - i only want client-side editing, with no buttons to write changes back (which would fail)
> Is this possible with the existing sourcecode, am i missing something?
> If not, perhaps we should seperate the funcionalities in the next mapbender-version
> into strictly client-side work (digitize) and server-side (saving, updating).
> Thomas
INTERGEO 2010
05.-07. Oktober 2010 in Köln
Halle 11.2, Stand 2C.121
www.intergeo.de
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
