[Mapbender_dev] Installation trunk
Astrid Emde astrid.emde at wheregroup.com
Tue Feb 1 03:16:15 EST 2011
Hi Christoph,
I also observed that gui and gui1 are very slow. But they show up in the
end. On Windows they are veryvery slow.
I also assume that this is connected to the WMC change.
When you set the element_var loadFromSession to 0 (element loadwmc) gui1
and gui2 load much faster.
We should add the element_var to each application and set the default to 0?
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
var_value, context, var_type) VALUES('gui2', 'loadwmc',
'loadFromSession', '0', '' ,'php_var');
Best regards Astrid
On Mon, January 31, 2011 9:39 pm, Christoph Baudson wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi there,
> currently I'm running into problems when installing Mapbender from trunk.
> The problem is in the applications gui1 and gui2. They simply don't
> load. There are no errors whatsoever, not in PHP or JS. I assume it must
> have something to do with the WMC that is generated on start-up, as both
> applications use EPSG:31467.
> I'm running Ubuntu 10.04 with Postgres 8.4, PostGIS 1.5 and PHP 5.3. The
> mapbender_setup.php is all green.
> Another problem I stumbled upon was in template_openlayers: Here there
> are still references to the minified jQuery UI files. The reason is that
> the INSERT of the application is after the UPDATE of the minified files. I
> have moved the UPDATE to the end of the SQL and committed it to trunk.
> I also replaced some occurences of split by explode, as split is
> deprecated.
> If you have any ideas why gui1 and gui2 don't load, please share.
> Talk to you soon,
> Christoph
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.10 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAk1HLBQACgkQGtMIfbycMX6mZwCfU2kWF2m3Ypie94irOdRBZSgz
> zzMAnj+DlK4+f/8YDHuNy+CNNcu6MsIr =HXoi
> -----END PGP SIGNATURE-----
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
Die WhereGroup zieht um ...
Ab dem 01.01.2011 lautet unsere neue Adresse:
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Alle Telefonnummern und eMail-Adressen
bleiben unverändert.
  Astrid Emde
  WhereGroup GmbH & Co.KG
  Eifelstraße 7
  53119 Bonn
  Germany
  Fon: +49(0)228 90 90 38 - 19
  Fax: +49(0)228 90 90 38 - 11
  www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
