[Mapbender_dev] Installation trunk
Armin Retterath armin.retterath at lvermgeo.rlp.de
Tue Feb 1 03:45:57 EST 2011
we should do this also for savewmc - saveInSession=0 ;-)
Am Dienstag 01 Februar 2011, um 09:16:15 schrieb Astrid Emde:
> Hi Christoph,
> I also observed that gui and gui1 are very slow. But they show up in the
> end. On Windows they are veryvery slow.
> I also assume that this is connected to the WMC change.
> When you set the element_var loadFromSession to 0 (element loadwmc) gui1
> and gui2 load much faster.
> We should add the element_var to each application and set the default to 0?
> INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
> var_value, context, var_type) VALUES('gui2', 'loadwmc',
> 'loadFromSession', '0', '' ,'php_var');
> Best regards Astrid
> On Mon, January 31, 2011 9:39 pm, Christoph Baudson wrote:
> > -----BEGIN PGP SIGNED MESSAGE-----
> > Hash: SHA1
> > Hi there,
> > currently I'm running into problems when installing Mapbender from trunk.
> > The problem is in the applications gui1 and gui2. They simply don't
> > load. There are no errors whatsoever, not in PHP or JS. I assume it must
> > have something to do with the WMC that is generated on start-up, as both
> > applications use EPSG:31467.
> > I'm running Ubuntu 10.04 with Postgres 8.4, PostGIS 1.5 and PHP 5.3. The
> > mapbender_setup.php is all green.
> > Another problem I stumbled upon was in template_openlayers: Here there
> > are still references to the minified jQuery UI files. The reason is that
> > the INSERT of the application is after the UPDATE of the minified files.
> > I have moved the UPDATE to the end of the SQL and committed it to trunk.
> > I also replaced some occurences of split by explode, as split is
> > deprecated.
> > If you have any ideas why gui1 and gui2 don't load, please share.
> > Talk to you soon,
> > Christoph
> > -----BEGIN PGP SIGNATURE-----
> > Version: GnuPG v1.4.10 (GNU/Linux)
> > Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> > iEYEARECAAYFAk1HLBQACgkQGtMIfbycMX6mZwCfU2kWF2m3Ypie94irOdRBZSgz
> > zzMAnj+DlK4+f/8YDHuNy+CNNcu6MsIr =HXoi
> > -----END PGP SIGNATURE-----
> > Mapbender_dev mailing list
> > Mapbender_dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Im Auftrag
Armin Retterath
Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
beim
Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
http://www.geoportal.rlp.de
More information about the Mapbender_dev mailing list
