Fwd: Re: Fwd: Re: [Mapbender_dev] Printing High Quality 288dpi Blank
PDF
Armin Retterath
armin.retterath at lvermgeo.rlp.de
Mon Jun 27 10:09:08 EDT 2011
forgot the answer :-(
---------- Weitergeleitete Nachricht ----------
Betreff: Re: Fwd: Re: [Mapbender_dev] Printing High Quality 288dpi Blank PDF
Datum: Montag 27 Juni 2011, 16:03:43
Von: Armin Retterath <armin.retterath at lvermgeo.rlp.de>
An: daveyclark <dclark at tayside-vjb.gov.uk>
hello dave,
you can redo the changes in the class_connector.php. i give the wrong line
cause you maybe have another version of mapbender.
the getmap you copied asks for a image with width 4240 and height 2880. this
is to much for the mapserver since you have only defined 2048 px for both!
the mapserver xml exception will show you this error.
please set the value for mapservers maxsize to 5000 and the image will be
printed ;-) .
regards
armin
Am Montag 27 Juni 2011, 15:44:10 schrieben Sie:
> Armin
> I have checked my wms.map file and there was no decleration of "MAXSIZE"
> that I could see anywhere. I put MAXSIZE 2048 in the wms.map beside the
> EXTENT, at the top of the file. I then updated my WMS and tried again but
> this made no difference.
> I have opened the class_connector.php file you are reffering to but cannot
> locate the line you are reffering to. I am opening the file in Dreamweaver
> and line 81 is }. Line 79 is: $e = new mb_notice("connector: curl without
> auth"); I tried replacing this line, with the line you suggested, then
> trying it and when I got nothing, calling up the error log file and I got
> the following error:
> 2011.06.27, 13:36:03,ERROR: weldMaps2PNG: unable to load image:
> http://myserver/cgi-bin/mapserv.exe?MAP=p:/ms4w/apps/tutorial/htdocs/wms.ma
> p&VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=fiftyk,boundary&STYLES=,&
> SRS=EPSG:27700&BBOX=334162.23214285716,728819.0310846561,345379.16335978836
> ,736438.0787037037&WIDTH=4240&HEIGHT=2880&FORMAT=image/png&BGCOLOR=0xffffff
> &TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_xml
> I then copied from the http, to the end and pasted this into the browser
> but as I expected, it just prompted me to save an xml file as thats what
> it was.
> Any ideas?
> Regards
> Dave
> http://osgeo-org.1803224.n2.nabble.com/Fwd-Re-Mapbender-dev-Printing-High-
> Quality-288dpi-Blank-PDF-tp6520128p6520450.html Sent from the mapbender-dev
> mailing list archive at Nabble.com.
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Im Auftrag
Armin Retterath
Zentrale Stelle Geodateninfrastruktur
LVermGeo RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
http://www.geoportal.rlp.de
Im Auftrag
Armin Retterath
LVermGeo RP
56073 Koblenz
More information about the Mapbender_dev
