[Mapbender_dev] Copyright on Print.
Armin Retterath armin.retterath at lvermgeo.rlp.de
Wed Dec 5 07:50:09 PST 2012
hello dave,
this depends wether you use the older style print module or the new one
../plugins/mb_print.php
with the new one you have options to generate your own templates - as
many as you want.
in the template you can put elements in and you have an option to use a
pdf template as a frame wherein the maps are printed.
the configuration are defined as json files.
the copyright statement is normally only a simpel link element. this is
not known to the mapbender print server module. maybe it will be easy to
print this element as an option of the json configuration but it will be
easier to define the copyright hardcoded in the pdf template ;-) .
please test the print module under http://www.geoportal.rlp.de
docs of the module:
http://www.mapbender.org/PrintPDF_with_template
if you have further questions - please ask them ;-)
regards
armin
On 05.12.2012 11:41, daveyclark wrote:
> Hi,
> I am wondering if someone can help me. I have a mapbender user interface
> working from a postgres database and Apache Web Server using Mapserver.
> I am using the PDF print and am wondering if anyone knows how to get the
> Copyright statment I have showing on my map on the screen, to appear on the
> print?
> I am assuming it can be added to the code somewhere in printPDF.conf or
> mod_printPDF.php or mod_printPDF_pdf.php? But I can't find where to add it?
> My versions of software are listed below:
> PostgreSQL 8.4/pg Admin III/ PostGIS 1.5
> Appache Web Server 2.2.15
> Mapbender 2.7
> MapServer 5.6.5 CGI and MapScript (CSharp, Java, PHP, Python)
> PHP 5.3.2
> Any help greatly appreaciated.
> Many Thanks in advance.
> Dave
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Copyright-on-Print-tp5020877.html
> Sent from the mapbender-dev mailing list archive at Nabble.com.
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Zentrale Stelle Geodateninfrastruktur
Rheinland-Pfalz
LVermGeo-RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
0261/492-466
More information about the Mapbender_dev mailing list
