[Mapbender-dev] [Mapbender_dev] Motion to use the issue tracker from github for Mapbender3
Thomas Baschetti
info at thomas-baschetti.de
Sun Feb 10 23:36:30 PST 2013
Hi all,
using Github sounds sensible, so +1.
Regarding different trackers or not: Don't know, whether we need it, but it
probably won't hurt, so +0 for this.
Thomas
On Fri, Feb 8, 2013 at 10:08 AM, Christian Wygoda <
christian.wygoda at wheregroup.com> wrote:
> Hi,
> a publicly facing tracker is definately needed and with the public code
> repo already hosted at Github, the motion would be the natural move.
> Therefore I +1 it.
> We probably would need the labels "Bug", "Feature", "Feature-Request".
> Right now the code is split up in three repositories:
> * mapbender-starter for the basic application skeleton
> * mapbender for the actual Mapbender code
> * fom for the "auxiliary" code like user management and backend
> infrastructure.
> I would favor trackers for each, even if that would probably mean that we
> need to shift tickets around from time to time if they are posted to the
> wrong repository.
> Cheers & Alaaf,
> Crischan
> On 02/07/2013 10:02 AM, Astrid Emde wrote:
>> Hello,
>> for Mapbender 2.x we used the issue tracker at trac
>> http://trac.osgeo.org/**mapbender/report<http://trac.osgeo.org/mapbender/report>
>> I would like to make the motion to use the github issue tracker for
>> Mapbender3 from the mapbender-repository
>> https://github.com/mapbender/**mapbender/issues<https://github.com/mapbender/mapbender/issues>
>> Ticktes for documentation could be made at:
>> https://github.com/mapbender/**mapbender-documentation/issues<https://github.com/mapbender/mapbender-documentation/issues>
>> What do you think about this idea? Please give feedback.
> FOSS Academy Winterschule, 25.02.-01.03.2013
> GDI in 5 Tagen!
> http://www.foss-academy.eu/**Winterschule_2013<http://www.foss-academy.eu/Winterschule_2013>
> WhereGroup GmbH & Co. KG
> Eifelstraße 7
> 53119 Bonn
> Germany
> Christian Wygoda
> Anwendungsentwickler
> Fon: +49 (0)228 / 90 90 38 - 15
> Fax: +49 (0)228 / 90 90 38 - 11
> info at wheregroup.com
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> ______________________________**_________________
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/mapbender_dev<http://lists.osgeo.org/mailman/listinfo/mapbender_dev>
Thomas Baschetti - Systemanalyse Geographische Informationssysteme
Hakenstraße 8D
49074 Osnabrück
Tel: 0541 25 91 90 | mobil 01577 189 25 91
E-Mail: info at thomas-baschetti.dewww.thomas-baschetti.de
Ust-IdNr.: DE264355072
URL: <http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20130211/525bbf04/attachment.html>
More information about the Mapbender_dev
