[Mapbender-dev] [Mapbender_dev] Motion to use the issue tracker from github for Mapbender3
Astrid Emde
astrid.emde at wheregroup.com
Tue Feb 12 00:32:52 PST 2013
Hello devs,
+1 to add labels (see mapbender-documentation - labels already exist:
bug, duplicate, enhancement, invalid, question, wontfix)
+1 to split up the tickets per repository (mapbender-starter, mapbender,
fom, mapbender-documentation)
Any other opinions?
Astrid
Am 11.02.2013 08:36, schrieb Thomas Baschetti:
> Hi all,
> using Github sounds sensible, so +1.
> Regarding different trackers or not: Don't know, whether we need it,
> but it probably won't hurt, so +0 for this.
> Thomas
> On Fri, Feb 8, 2013 at 10:08 AM, Christian Wygoda
> <christian.wygoda at wheregroup.com
> <mailto:christian.wygoda at wheregroup.com>> wrote:
> Hi,
> a publicly facing tracker is definately needed and with the public
> code repo already hosted at Github, the motion would be the
> natural move. Therefore I +1 it.
> We probably would need the labels "Bug", "Feature",
> "Feature-Request". Right now the code is split up in three
> repositories:
> * mapbender-starter for the basic application skeleton
> * mapbender for the actual Mapbender code
> * fom for the "auxiliary" code like user management and backend
> infrastructure.
> I would favor trackers for each, even if that would probably mean
> that we need to shift tickets around from time to time if they are
> posted to the wrong repository.
> Cheers & Alaaf,
> Crischan
> On 02/07/2013 10:02 AM, Astrid Emde wrote:
> Hello,
> for Mapbender 2.x we used the issue tracker at trac
> http://trac.osgeo.org/mapbender/report
> I would like to make the motion to use the github issue
> tracker for
> Mapbender3 from the mapbender-repository
> https://github.com/mapbender/mapbender/issues
> Ticktes for documentation could be made at:
> https://github.com/mapbender/mapbender-documentation/issues
> What do you think about this idea? Please give feedback.
> FOSS Academy Winterschule, 25.02.-01.03.2013
> GDI in 5 Tagen!
> http://www.foss-academy.eu/Winterschule_2013
> WhereGroup GmbH & Co. KG
> Eifelstraße 7
> 53119 Bonn
> Germany
> Christian Wygoda
> Anwendungsentwickler
> Fon: +49 (0)228 / 90 90 38 - 15
> <tel:%2B49%20%280%29228%20%2F%2090%2090%2038%20-%2015>
> Fax: +49 (0)228 / 90 90 38 - 11
> <tel:%2B49%20%280%29228%20%2F%2090%2090%2038%20-%2011>
> info at wheregroup.com <mailto:info at wheregroup.com>
> www.wheregroup.com <http://www.wheregroup.com>
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org <mailto:Mapbender_dev at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
> -- Thomas Baschetti - Systemanalyse Geographische Informationssysteme
> Hakenstraße 8D 49074 Osnabrück Tel: 0541 25 91 90 | mobil 01577 189 25
> 91 E-Mail: info at thomas-baschetti.de <mailto:info at thomas-baschetti.de>
> www.thomas-baschetti.de <http://www.thomas-baschetti.de/> Ust-IdNr.:
> DE264355072
Mit freundlichen Grüßen
Astrid Emde
GDI in 5 Tagen!
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Komplementärin:
vertreten durch:
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
URL: <http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20130212/19f6b834/attachment.html>
More information about the Mapbender_dev
