[Mapbender-dev] [Mapbender_dev] Motion to use the issue tracker from github for Mapbender3
Astrid Emde astrid.emde at wheregroup.com
Tue Feb 19 01:16:44 PST 2013
Hello dev, hello PSC,
thanks for all your feedback concerning using the tracker.
We will now use the tracker in future to document enhancements and bugs
n Mapbender3 to let the community know what is happening in the project.
We use the trackers for every repository as Christian suggested that means:
https://github.com/mapbender/mapbender/issues
https://github.com/mapbender/mapbender-starter/issues
https://github.com/mapbender/fom/issues
https://github.com/mapbender/mapbender-documentation/issues
Please refer your tickets to Milestone 3.0 at the moment.
If you want to get notifications edit your profile:
https://github.com/settings/notifications
And check the repositories you are watching
https://github.com/watching
Best regards Astrid
Am 12.02.2013 09:32, schrieb Astrid Emde:
> Hello devs,
> +1 to add labels (see mapbender-documentation - labels already exist:
> bug, duplicate, enhancement, invalid, question, wontfix)
> +1 to split up the tickets per repository (mapbender-starter,
> mapbender, fom, mapbender-documentation)
> Any other opinions?
> Astrid
> Am 11.02.2013 08:36, schrieb Thomas Baschetti:
>> Hi all,
>> using Github sounds sensible, so +1.
>> Regarding different trackers or not: Don't know, whether we need it,
>> but it probably won't hurt, so +0 for this.
>> Thomas
>> On Fri, Feb 8, 2013 at 10:08 AM, Christian Wygoda
>> <christian.wygoda at wheregroup.com
>> <mailto:christian.wygoda at wheregroup.com>> wrote:
>>     Hi,
>>     a publicly facing tracker is definately needed and with the
>>     public code repo already hosted at Github, the motion would be
>>     the natural move. Therefore I +1 it.
>>     We probably would need the labels "Bug", "Feature",
>>     "Feature-Request". Right now the code is split up in three
>>     repositories:
>>     * mapbender-starter for the basic application skeleton
>>     * mapbender for the actual Mapbender code
>>     * fom for the "auxiliary" code like user management and backend
>>     infrastructure.
>>     I would favor trackers for each, even if that would probably mean
>>     that we need to shift tickets around from time to time if they
>>     are posted to the wrong repository.
>>     Cheers & Alaaf,
>>       Crischan
>>     On 02/07/2013 10:02 AM, Astrid Emde wrote:
>>         Hello,
>>         for Mapbender 2.x we used the issue tracker at trac
>>         http://trac.osgeo.org/mapbender/report
>>         I would like to make the motion to use the github issue
>>         tracker for
>>         Mapbender3 from the mapbender-repository
>>         Ticktes for documentation could be made at:
>>         What do you think about this idea? Please give feedback.
>>     FOSS Academy Winterschule, 25.02.-01.03.2013
>>     GDI in 5 Tagen!
>>     http://www.foss-academy.eu/Winterschule_2013
>>     WhereGroup GmbH & Co. KG
>>     Eifelstraße 7
>>     53119 Bonn
>>     Germany
>>     Christian Wygoda
>>     Anwendungsentwickler
>>     Fon: +49 (0)228 / 90 90 38 - 15
>>     <tel:%2B49%20%280%29228%20%2F%2090%2090%2038%20-%2015>
>>     Fax: +49 (0)228 / 90 90 38 - 11
>>     <tel:%2B49%20%280%29228%20%2F%2090%2090%2038%20-%2011>
>>     info at wheregroup.com <mailto:info at wheregroup.com>
>>     www.wheregroup.com <http://www.wheregroup.com>
>>     Amtsgericht Bonn, HRA 6788
>>     Komplementärin:
>>     WhereGroup Verwaltungs GmbH
>>     vertreten durch:
>>     Olaf Knopp, Peter Stamm
>>     _______________________________________________
>>     Mapbender_dev mailing list
>>     Mapbender_dev at lists.osgeo.org <mailto:Mapbender_dev at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/mapbender_dev
>> -- Thomas Baschetti - Systemanalyse Geographische Informationssysteme
>> Hakenstraße 8D 49074 Osnabrück Tel: 0541 25 91 90 | mobil 01577 189
>> 25 91 E-Mail: info at thomas-baschetti.de
>> <mailto:info at thomas-baschetti.de> www.thomas-baschetti.de
>> <http://www.thomas-baschetti.de/> Ust-IdNr.: DE264355072
> Mit freundlichen Grüßen
> Astrid Emde
> GDI in 5 Tagen!
>  Astrid Emde
>  WhereGroup GmbH & Co.KG
>  Eifelstraße 7
>  53119 Bonn
>  Germany
>  Fon: +49(0)228 90 90 38 - 19
>  Fax: +49(0)228 90 90 38 - 11
>  www.wheregroup.com
>  Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> Komplementärin:
> vertreten durch:
>  pgp-public key:
>  http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
>   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>   Signed and/or encrypted mail is highly appreciated
Astrid Emde
GDI in 5 Tagen!
 Astrid Emde
 Eifelstraße 7
 53119 Bonn
 Germany
 www.wheregroup.com
Komplementärin:
vertreten durch:
 pgp-public key:
URL: <http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20130219/0c67cc29/attachment.html>
More information about the Mapbender_dev mailing list
