[Mapbender-dev] Mapbender3 - individual FeatureInfo Style with Inline Styles
Astrid Emde astrid.emde at wheregroup.com
Tue Jun 24 00:39:21 PDT 2014
Hello,
some Mapbender3 users noticed that their FeatureInfo template style got
lost when they use Mapbender3.
Mapbender3 ignores the external and internal Style Sheets that are used
to avoid negative effects on the Mapbender3 application itself. The css
can't be capsuled these days by the browsers. The FeatureInfo style can
only be used if you open the FeatureInfo result in a new window.
If you still want to use your indvidual style you can use inline styles.
That means you add the style attribute to the relevant tag.
<p style="color:red;margin-left:20px;">Test</p>
or
<table border='1'>
Read more
https://developer.mozilla.org/de/docs/Web/CSS
Best regards
Astrid Emde
GIS-Consultant
Treffen Sie die WhereGroup auf der AGIT 2014
2.-4. Juli 2014 in Salzburg | www.agit.at
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Eifelstraße 7
 53119 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
 Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
 pgp-public key:
 http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
  Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_dev mailing list
