[Mapbender-dev] Mapbender3 - Symfony URL validator does not accept URLs without a dot (.)
Astrid Emde
astrid.emde at wheregroup.com
Tue Jun 24 01:00:42 PDT 2014
Hello,
the Symfony URL validator does not accept URLs without a dot (.) like
localhost or a986123demo:8399 in Symfony version 2.1 which is used in
Mapbender3 at the moment.
This is a upstream Symfony bug which is solved in version 2.3. We use
Symfony 2.1 at the moment.
With the next Mapbender3 version in August 2014 we will move to Symfony
2.3. So the problem should be fixed in mapbender3 too.
Here is the Mapbender3 ticket about this issue
https://github.com/mapbender/mapbender/issues/16
WORKAROUND to load a WMS from localhost
* use 127.0.0.1 instead of localhost
WORKAROUND to load a WMS from an addres without dot (.)
* open the getCapabilities-Url in the browser and save the document as a
file in a directory which can be refered from the browser
* refer to the file-URL to load the WMS
Best regards
Astrid Emde
GIS-Consultant
Treffen Sie die WhereGroup auf der AGIT 2014
2.-4. Juli 2014 in Salzburg | www.agit.at
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_dev
