[Mapbender-dev] Fwd: MS4W version 4.0.0 pre-release 'alpha' available
Astrid Emde
astrid.emde at wheregroup.com
Mon Jun 27 14:31:53 PDT 2016
Hello Jeff,
thanks for your mail.
The actual version 3.0.5.3 does not fully support PHP 7. It has problems
with printing.
We fixed this already in the release branch 3.0.5. With the next release
3.0.5.4 we will be ready for PHP7.
You can get the nightly package at:
http://mapbender3.org/builds/nightly/
We updated the windows requirement list for PHP7 already:
http://doc.mapbender3.org/en/book/installation/installation_windows.html
PHP zip as additional extension is needed.
# php.ini
# Download PHP Zip http://pecl.php.net/package/zip/1.13.2/windows
extension=php_zip.dll
I will let you know, when 3.0.5.4 comes out and can get integrated to
ms4w.
Astrid
Am 2016-06-27 20:13, schrieb Jeff McKenna:
> Forwarding to the Mapbender developers, as this MS4W version includes
> custom built PHP and Apache for the Mapbender requirements on Windows,
> to give them a heads up on testing for PHP 7 and providing feedback.
> Thank you. -jeff
> -------- Forwarded Message --------
> Subject: Re: [MS4W-Users] version 4.0.0 pre-release 'alpha' available
> Date: Mon, 27 Jun 2016 12:42:11 -0300
> From: Jeff McKenna via MS4W-Users <ms4w-users at lists.ms4w.com>
> Reply-To: ms4w-users at lists.ms4w.com
> CC: Jeff McKenna <jmckenna at gatewaygeomatics.com>
> Hello everyone,
> Another alpha build (alpha3) is now available on the download server
> (http://www.ms4w.com/release/experimental/), which contains PHP 7.0.8
> as well as its extensions. Thank you to those who had filed tickets
> for specific PHP extensions (at http://ms4w.com/trac). Note that most
> of the extensions are loaded by default in PHP, so the best way to
> check what extensions are included is through a phpinfo() call (there
> is a 'phpinfo.php' file already included in /ms4w/apache/htdocs/
> Technical users might want to check the configure command used when I
> compiled this PHP, which is shown in the phpinfo() results (or here is
> a screenshot, see the 5th row in the table:
> http://pasteboard.co/1ZYfzJyX.png). Don't be afraid to request
> additional extensions through the MS4W tracker: http://ms4w.com/trac -
> the time is now for feedback and requests.
> PHP 7 is of course a big improvement (and I've invested almost 2
> months of my time to rebuild the entire MS4W stack for PHP 7, which
> requires the latest compiler). You can check online for performance
> improvements of PHP 7, most estimate 3X speed improvements with this
> version (wow). An important note of course is that PHPMapScript is not
> yet included in the alpha, as it definitely requires additional
> development time and effort; so please please contact me directly if
> your organization can help fund this effort.
> Thank you for using MS4W.
> -jeff
> Please check the 'HISTORY.txt' file in the alpha, for a list of
> changes in your alpha build.
> To use these alpha builds, be sure to install the 'Microsoft Visual
> C++ 2015 Redistributable Update 2
> ' package first (vc_redist.x86.exe):
> https://www.microsoft.com/en-us/download/details.aspx?id=51682 An
> important note: because of this new compiler, old systems running
> Windows XP (and possible Windows Server 2003) can no longer be
> supported. But of course if need be, I can provide custom builds with
> the old compiler for those organizations requiring that.
> I realize that so many organizations (many on this mailing list) rely
> heavily on MS4W, so please contact me directly to help support its
> development with funding. It is very important.
> Below is a list of recent changes. If you want the latest stable MS4W
> release, please download last month's MS4W 3.1.4 release (from
> http://ms4w.com/).
> 2016-06-27 Gateway Geomatics
> * ms4w version 4.0.0-alpha3 created. Notable changes are:
> - upgraded PHP to 7.0.8 with Visual Studio 2015 compiler
> (trac ticket 5)
> - built additional PHP extensions with Visual Studio 2015
> compiler:
> pdo_mysql (trac ticket 52), pdo_oci, oci8, bzip2
> - rebuilt all GDAL plugins and bindings
> - moved CSharp, Java, Python bindings into folder
> /ms4w/gdalbindings/
> - updated script /gdalbindings/python/test-cgi-mapscript.py
> for Python 3
> *PHPMapScript will not work in this version, needs dev work +
> funding
> 2016-06-20 Gateway Geomatics
> * ms4w version 4.0.0-alpha2 created. Notable changes are:
> - rebuilt MapServer 7.1-dev with Visual Studio 2015 compiler
> - rebuilt Apache with Visual Studio 2015 compiler
> - upgraded MapCache to 1.5-dev with Visual Studio 2015
> compiler
> - rebuilt mod_fcgid with Visual Studio 2015 compiler
> - upgraded OpenSSL support to 1.0.2h with Visual Studio 2015
> compiler
> - upgraded cURL support to 7.49.1 with Visual Studio 2015
> compiler
> - rebuilt Apache H264 Streaming Module with Visual Studio
> 2015 compiler
> - upgraded BerkeleyDB support to 6.2.23 with Visual Studio
> 2015 compiler
> *still need to rebuild PHP 7 (& its extensions), therefore
> PHP & MapScript
> 2016-05-06 Gateway Geomatics
> * ms4w version 3.1.4 created. Notable changes are:
> - upgraded GDAL to 2.1.0 (trac ticket 50)
> - upgraded Apache to 2.4.20 (trac ticket 55)
> - upgraded OpenSSL support to 1.0.2h (trac ticket 57)
> - upgraded CURL support to 7.48.0
> 2016-04-21 Gateway Geomatics
> * ms4w version 4.0.0-alpha1 created. Notable changes are:
> - rebuilt JPEG support with Visual Studio 2015 compiler
> - rebuilt zlib support with Visual Studio 2015 compiler
> - rebuilt libPNG support with Visual Studio 2015 compiler
> - rebuilt libTIFF support with Visual Studio 2015 compiler
> - rebuilt PROJ.4 support with Visual Studio 2015 compiler
> - upgraded GeoTIFF support to SVN-trunk-03282016 with Visual
> - upgraded Expat support to 2.1.1 with Visual Studio 2015
> compiler
> - upgraded Xerces support to 3.1.3 with Visual Studio 2015
> compiler
> - rebuilt SZIP support with Visual Studio 2015 compiler
> - upgraded MrSID support to SDK 9.5.1 with Visual Studio 2015
> compiler
> - upgraded PostgreSQL support to 9.5.2 with Visual Studio
> 2015 compiler
> - upgraded MySQL support to 5.7.11 with Visual Studio 2015
> compiler
> - upgraded GEOS support to SVN-trunk-0404016 with Visual
> - upgraded SQLite support to 3.12.0 with Visual Studio 2015
> compiler
> - upgraded ICONV support to 1.14 with Visual Studio 2015
> compiler
> - upgraded FreeXL support to 1.0.2 with Visual Studio 2015
> compiler
> - rebuilt libxml2 support with Visual Studio 2015 compiler
> - upgraded Python support to 3.5.1 with Visual Studio 2015
> compiler
> - upgraded MySQL support to 5.7.12 with Visual Studio 2015
> compiler
> - upgraded SpatiaLite support to 4.4.0-RC0 with Visual
> - rebuilt ReadOSM support with Visual Studio 2015 compiler
> - upgraded spatialite-tools support to 4.4.0-RC0 with Visual
> - upgraded FITS support to 3.380 with Visual Studio 2015
> compiler
> - rebuilt OpenSSL support with Visual Studio 2015 compiler
> - upgraded cURL support to 7.48.0 with Visual Studio 2015
> compiler
> - rebuilt NetCDF support with Visual Studio 2015 compiler
> - upgraded LibKML support to git-04182016 with Visual Studio
> 2015 compiler
> - upgraded Freetype support to 2.6.3 with Visual Studio 2015
> compiler
> - upgraded Pixman support to 0.34.0 with Visual Studio 2015
> compiler
> - rebuilt Cairo support with Visual Studio 2015 compiler
> - rebuilt Poppler support with Visual Studio 2015 compiler
> - upgraded SWIG support to 3.0.8 with Visual Studio 2015
> compiler
> - rebuilt Python, Oracle GDAL plugins with Visual Studio 2015
> compiler
> - added Java, CSharp, ECW (3.3 SDK) GDAL plugins with Visual
> - moved all GDAL plugins into /gdalplugins/
> - added HDF5 1.8.16 support with Visual Studio 2015 compiler
> - added HDF4 4.2.11 support with Visual Studio 2015 compiler
> - upgraded GDAL support to 2.1.0-dev with Visual Studio 2015
> compiler
> - upgraded PCRE support to 8.38 with Visual Studio 2015
> compiler
> - rebuilt FriBidi support with Visual Studio 2015 compiler
> - upgraded HarfBuzz support to 1.2.6 with Visual Studio 2015
> compiler
> - upgraded GIFLIB support to 5.1.2 with Visual Studio 2015
> compiler
> - rebuilt FastCGI support with Visual Studio 2015 compiler
> *still need to rebuild MapServer (& its libraries), Apache
> (& its modules), PHP (& its extensions), ...
> *therefore MapServer, Apache, PHP will not work in this
> version
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
FOSSGIS Konferenz 2016 und AGIT 2016
4.-6. Juli 2016 & 6.-8. Juli 2016 in Salzburg
http://fossgis-konferenz.de/2016/
http://agit.at/
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_dev
