[Mapbender-dev] Fwd: MS4W version 4.0.0 pre-release 'alpha' available
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Jun 27 15:45:42 PDT 2016
Hi Astrid,
Thank you for your response.
Actually the php_zip extension is enabled by default in MS4W's PHP 7, so
Mapbender users can test these nightly builds without any configuration
required :) Please if anyone finds any issues with this 'alpha' MS4W
build let me know.
Thanks for letting me know about the upcoming 3.0.5.4 release with PHP 7
support, I will be sure to include that release for the MS4W community.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-06-27 6:31 PM, Astrid Emde wrote:
> Hello Jeff,
> thanks for your mail.
> The actual version 3.0.5.3 does not fully support PHP 7. It has problems
> with printing.
> We fixed this already in the release branch 3.0.5. With the next release
> 3.0.5.4 we will be ready for PHP7.
> You can get the nightly package at:
> http://mapbender3.org/builds/nightly/
> We updated the windows requirement list for PHP7 already:
> http://doc.mapbender3.org/en/book/installation/installation_windows.html
> PHP zip as additional extension is needed.
> # php.ini
> # Download PHP Zip http://pecl.php.net/package/zip/1.13.2/windows
> extension=php_zip.dll
> I will let you know, when 3.0.5.4 comes out and can get integrated to ms4w.
> Astrid
> Am 2016-06-27 20:13, schrieb Jeff McKenna:
>> Forwarding to the Mapbender developers, as this MS4W version includes
>> custom built PHP and Apache for the Mapbender requirements on Windows,
>> to give them a heads up on testing for PHP 7 and providing feedback.
>> Thank you. -jeff
>> -------- Forwarded Message --------
>> Subject: Re: [MS4W-Users] version 4.0.0 pre-release 'alpha' available
>> Date: Mon, 27 Jun 2016 12:42:11 -0300
>> From: Jeff McKenna via MS4W-Users <ms4w-users at lists.ms4w.com>
>> Reply-To: ms4w-users at lists.ms4w.com
>> CC: Jeff McKenna <jmckenna at gatewaygeomatics.com>
>> Hello everyone,
>> Another alpha build (alpha3) is now available on the download server
>> (http://www.ms4w.com/release/experimental/), which contains PHP 7.0.8
>> as well as its extensions. Thank you to those who had filed tickets
>> for specific PHP extensions (at http://ms4w.com/trac). Note that most
>> of the extensions are loaded by default in PHP, so the best way to
>> check what extensions are included is through a phpinfo() call (there
>> is a 'phpinfo.php' file already included in /ms4w/apache/htdocs/
>> Technical users might want to check the configure command used when I
>> compiled this PHP, which is shown in the phpinfo() results (or here is
>> a screenshot, see the 5th row in the table:
>> http://pasteboard.co/1ZYfzJyX.png). Don't be afraid to request
>> additional extensions through the MS4W tracker: http://ms4w.com/trac -
>> the time is now for feedback and requests.
>> PHP 7 is of course a big improvement (and I've invested almost 2
>> months of my time to rebuild the entire MS4W stack for PHP 7, which
>> requires the latest compiler). You can check online for performance
>> improvements of PHP 7, most estimate 3X speed improvements with this
>> version (wow). An important note of course is that PHPMapScript is not
>> yet included in the alpha, as it definitely requires additional
>> development time and effort; so please please contact me directly if
>> your organization can help fund this effort.
>> Thank you for using MS4W.
>> -jeff
>> Please check the 'HISTORY.txt' file in the alpha, for a list of
>> changes in your alpha build.
>> To use these alpha builds, be sure to install the 'Microsoft Visual
>> C++ 2015 Redistributable Update 2
>> ' package first (vc_redist.x86.exe):
>> https://www.microsoft.com/en-us/download/details.aspx?id=51682 An
>> important note: because of this new compiler, old systems running
>> Windows XP (and possible Windows Server 2003) can no longer be
>> supported. But of course if need be, I can provide custom builds with
>> the old compiler for those organizations requiring that.
>> I realize that so many organizations (many on this mailing list) rely
>> heavily on MS4W, so please contact me directly to help support its
>> development with funding. It is very important.
>> Below is a list of recent changes. If you want the latest stable MS4W
>> release, please download last month's MS4W 3.1.4 release (from
>> http://ms4w.com/).
>> 2016-06-27 Gateway Geomatics
>> * ms4w version 4.0.0-alpha3 created. Notable changes are:
>> - upgraded PHP to 7.0.8 with Visual Studio 2015 compiler
>> (trac ticket 5)
>> - built additional PHP extensions with Visual Studio 2015
>> compiler:
>> pdo_mysql (trac ticket 52), pdo_oci, oci8, bzip2
>> - rebuilt all GDAL plugins and bindings
>> - moved CSharp, Java, Python bindings into folder
>> /ms4w/gdalbindings/
>> - updated script /gdalbindings/python/test-cgi-mapscript.py
>> for Python 3
>> *PHPMapScript will not work in this version, needs dev work
>> + funding
>> 2016-06-20 Gateway Geomatics
>> * ms4w version 4.0.0-alpha2 created. Notable changes are:
>> - rebuilt MapServer 7.1-dev with Visual Studio 2015 compiler
>> - rebuilt Apache with Visual Studio 2015 compiler
>> - upgraded MapCache to 1.5-dev with Visual Studio 2015 compiler
>> - rebuilt mod_fcgid with Visual Studio 2015 compiler
>> - upgraded OpenSSL support to 1.0.2h with Visual Studio 2015
>> compiler
>> - upgraded cURL support to 7.49.1 with Visual Studio 2015
>> compiler
>> - rebuilt Apache H264 Streaming Module with Visual Studio
>> 2015 compiler
>> - upgraded BerkeleyDB support to 6.2.23 with Visual Studio
>> 2015 compiler
>> *still need to rebuild PHP 7 (& its extensions), therefore
>> PHP & MapScript
>> 2016-05-06 Gateway Geomatics
>> * ms4w version 3.1.4 created. Notable changes are:
>> - upgraded GDAL to 2.1.0 (trac ticket 50)
>> - upgraded Apache to 2.4.20 (trac ticket 55)
>> - upgraded OpenSSL support to 1.0.2h (trac ticket 57)
>> - upgraded CURL support to 7.48.0
>> 2016-04-21 Gateway Geomatics
>> * ms4w version 4.0.0-alpha1 created. Notable changes are:
>> - rebuilt JPEG support with Visual Studio 2015 compiler
>> - rebuilt zlib support with Visual Studio 2015 compiler
>> - rebuilt libPNG support with Visual Studio 2015 compiler
>> - rebuilt libTIFF support with Visual Studio 2015 compiler
>> - rebuilt PROJ.4 support with Visual Studio 2015 compiler
>> - upgraded GeoTIFF support to SVN-trunk-03282016 with Visual
>> - upgraded Expat support to 2.1.1 with Visual Studio 2015
>> compiler
>> - upgraded Xerces support to 3.1.3 with Visual Studio 2015
>> compiler
>> - rebuilt SZIP support with Visual Studio 2015 compiler
>> - upgraded MrSID support to SDK 9.5.1 with Visual Studio
>> 2015 compiler
>> - upgraded PostgreSQL support to 9.5.2 with Visual Studio
>> 2015 compiler
>> - upgraded MySQL support to 5.7.11 with Visual Studio 2015
>> compiler
>> - upgraded GEOS support to SVN-trunk-0404016 with Visual
>> - upgraded SQLite support to 3.12.0 with Visual Studio 2015
>> compiler
>> - upgraded ICONV support to 1.14 with Visual Studio 2015
>> compiler
>> - upgraded FreeXL support to 1.0.2 with Visual Studio 2015
>> compiler
>> - rebuilt libxml2 support with Visual Studio 2015 compiler
>> - upgraded Python support to 3.5.1 with Visual Studio 2015
>> compiler
>> - upgraded MySQL support to 5.7.12 with Visual Studio 2015
>> compiler
>> - upgraded SpatiaLite support to 4.4.0-RC0 with Visual
>> - rebuilt ReadOSM support with Visual Studio 2015 compiler
>> - upgraded spatialite-tools support to 4.4.0-RC0 with Visual
>> - upgraded FITS support to 3.380 with Visual Studio 2015
>> compiler
>> - rebuilt OpenSSL support with Visual Studio 2015 compiler
>> - upgraded cURL support to 7.48.0 with Visual Studio 2015
>> compiler
>> - rebuilt NetCDF support with Visual Studio 2015 compiler
>> - upgraded LibKML support to git-04182016 with Visual Studio
>> 2015 compiler
>> - upgraded Freetype support to 2.6.3 with Visual Studio 2015
>> compiler
>> - upgraded Pixman support to 0.34.0 with Visual Studio 2015
>> compiler
>> - rebuilt Cairo support with Visual Studio 2015 compiler
>> - rebuilt Poppler support with Visual Studio 2015 compiler
>> - upgraded SWIG support to 3.0.8 with Visual Studio 2015
>> compiler
>> - rebuilt Python, Oracle GDAL plugins with Visual Studio
>> 2015 compiler
>> - added Java, CSharp, ECW (3.3 SDK) GDAL plugins with Visual
>> - moved all GDAL plugins into /gdalplugins/
>> - added HDF5 1.8.16 support with Visual Studio 2015 compiler
>> - added HDF4 4.2.11 support with Visual Studio 2015 compiler
>> - upgraded GDAL support to 2.1.0-dev with Visual Studio 2015
>> compiler
>> - upgraded PCRE support to 8.38 with Visual Studio 2015
>> compiler
>> - rebuilt FriBidi support with Visual Studio 2015 compiler
>> - upgraded HarfBuzz support to 1.2.6 with Visual Studio 2015
>> compiler
>> - upgraded GIFLIB support to 5.1.2 with Visual Studio 2015
>> compiler
>> - rebuilt FastCGI support with Visual Studio 2015 compiler
>> *still need to rebuild MapServer (& its libraries), Apache
>> (& its modules), PHP (& its extensions), ...
>> *therefore MapServer, Apache, PHP will not work in this version
More information about the Mapbender_dev
