[Mapbender-dev] Mapbender 3.0.8 released 2019-04-12
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Apr 12 05:38:04 PDT 2019
The release tags are missing a required file /app/bootstrap.php.cache
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2019-04-12 7:38 AM, Astrid Emde (WhereGroup) wrote:
> See german version below
> ============ english =================
> Dear Mapbender-Users and Mapbender-Developers,
> on 2018-04-12 we published version 3.0.8 of Mapbender. Thanks to all
> people involved!
> This version is a long-term-support version (LTS version) with some new
> features and several bugfixes. We will provide security fixes for the
> LTS verson till 2021-03-31.
> Please refer to changelog to find out about the changes [1]
> Download: https://mapbender.org/?q=en/download or directly via the link
> [2].
> Tag v3.0.8 at GitHub [3]
> https://github.com/mapbender/mapbender-starter/releases/tag/v3.0.8
> There are some changes in the database. So please please call the
> doctrine:schema:update command to update the database. See
> documentation: https://doc.mapbender.org/en/installation/update.html
> If you would like to work and develop with the source code read the
> Developer Guide (Contributing.md) [4]:
> https://github.com/mapbender/mapbender-starter/blob/master/CONTRIBUTING.md
> Report bugs [5]: https://github.com/mapbender/mapbender/issues
> Documentation [6]: https://doc.mapbender.org/en/
> Installation and Update: https://doc.mapbender.org/en/installation.html
> Try Mapbender and follow the Mapbender quickstart
> https://doc.mapbender.org/en/quickstart.html
> Mapbender-demo [7] https://demo.mapbender.org/
> The Mapbender team is working on the next version 3.1. We plan to
> publish this version in 2019. This version will use OpenLayers 4 and
> will provide a responsive design. This is the biggest change of the last
> years for the software. The Team says thank you to all the sponsors for
> the financial support and to the community. Sponsors for Mapbender 3.1
> are Vattenfall, Stromnetz Hamburg and City of Gütersloh and City of
> Troisdorf.
> Best regards
> Mapbender Team
> ============= deutsch ===============
> Hallo Mapbender-Community,
> das Mapbender-Entwicklungsteam hat die Mapbender-Version 3.0.8. am
> 12.8.2019 veröffentlicht. Herzlichen Dank an alle Beteiligten.
> Es handelt sich bei dieser Version um eine Long-Term-Support-Version
> (LTS-Version).
> Der Schwerpunkt wurde hier auf Stabilität und Performanz gelegt.
> Zahlreiche kleinere Bugs wurden gefixt, mehrere neue Features der
> letzten Versionen optimiert und alles umfangreich getestet.
> Highlights der neuen Version sind u.a. :
> Performanz, Sicherheit und Einbindung wurden verbessert für den
> Dimensionhandler, das Redlining, die Einbindung von Funktionen in das
> Sidepane und das Mobile Template.
> Das neue Feature in der Druck-Engine, die Warteschleife für
> Druckaufträge, ermöglicht den Druck von A0 auch ohne Print-Server.
> Außerdem werden große Legendenbilder besser skaliert und mehrzeilige
> Fließtexte in Freifelder und Titel unterstützt.
> Layer-Titel können beim WMS-Reload nun automatisch aktualisiert werden.
> Alle Überarbeitungen im Detail können dem Change-Log [1] entnommen
> werden. Insgesamt handelt es sich um über 50 Enhancements und Fixes.
> Die Version 3.0.8. wird als LTS-Version bis zum 31.03.2021 mit
> Sicherheitsaktualisierungen versorgt.
> Für 2019 ist außerdem die Veröffentlichung der Mapbender-Version 3.1
> vorgesehen. Damit verbunden ist die Anhebung des Kartenframeworks auf
> OpenLayers 4 und ein Responsive Design geplant. Dies ist die größte
> Veränderung der Software der letzten Jahre. Das Team bedankt sich an
> dieser Stelle für die finanzielle Unterstützung, die es aus der
> Community gab. Dazu gehören u. a. Vattenfall, Stromnetz Hamburg sowie
> die Städte Gütersloh und Troisdorf.
> Download 3.0.8: http://mapbender.org/?q=de/download oder direkt unter [2].
> Tag v3.0.8 auf GitHub [3]
> Es liegen ein paar Änderungen in der Datenbank vor. Führen Sie daher
> doctrine:schema:update durch. Siehe Dokumentation:
> https://doc.mapbender.org/de/installation/update.html
> Helfen Sie mit Mapbender weiterzuentwickeln: Developer Guide
> Melden Sie Bugs [5]: https://github.com/mapbender/mapbender/issues
> Dokumentation [6]: https://doc.mapbender.org/de/
> Informationen zur Installation und Aktualisierung auf eine neue Version:
> http://doc.mapbender.org/de/installation.html
> Probieren Sie Mapbender aus. Es gibt ein Mapbender-Tutorial, das die
> ersten Schritte mit Ihnen durchgeht:
> https://doc.mapbender.org/de/quickstart.html
> Probieren Sie die neue Version direkt aus: Mapbender-Demo [7]
> Viel Spaß mit der neuen Version wünscht
> Das Mapbender Team
> Links
> [1] https://github.com/mapbender/mapbender/releases
> [2] https://www.mapbender.org/builds/mapbender-starter-current.tar.gz
> [3] https://github.com/mapbender/mapbender-starter/releases/tag/v3.0.8
> [4]
> [5] https://github.com/mapbender/mapbender/issues
> [6] https://doc.mapbender.org/
> [7] Mapbender-Demo: https://demo.mapbender.org/
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev
