[Mapbender-dev] Mapbender 3.0.8 released 2019-04-12
Rolf Neuberger
Rolf.Neuberger at wheregroup.com
Mon Apr 15 01:31:17 PDT 2019
This is generated code. It's not under version control.
The file is automatically generated by the bootstrap script in the
project root, and implicitly also every time a compser package is
installed or updated.
You can explicitly trigger just the rebuild with a shell command:
application$ bin/composer run build-bootstrap
HTH,
-Rolf
On 12.04.19 14:38, Jeff McKenna wrote:
> The release tags are missing a required file /app/bootstrap.php.cache
> -jeff
Rolf Neuberger
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 0
Fax: +49 (0)228 / 90 90 38 - 11
rolf.neuberger at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
