[Mapbender-dev] Mapbender 3.0.8 released 2019-04-12
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Apr 15 04:45:21 PDT 2019
For example: mapbender3-starter-3.0.7.7.zip contained that missing file
(which I realize is not under version control, but was packaged in
previous releases).
I have never had to run that command in any previous release.  I also
notice that that command is not part of the Mapbender installation
documentation.
So my point is, something has changed with that 3.0.8 archive.
-jeff
On 2019-04-15 5:31 AM, Rolf Neuberger wrote:
> This is generated code. It's not under version control.
> The file is automatically generated by the bootstrap script in the
> project root, and implicitly also every time a compser package is
> installed or updated.
> You can explicitly trigger just the rebuild with a shell command:
> application$ bin/composer run build-bootstrap
> HTH,
> -Rolf
> On 12.04.19 14:38, Jeff McKenna wrote:
>> The release tags are missing a required file /app/bootstrap.php.cache
>> -jeff
More information about the Mapbender_dev mailing list
