[Mapbender-dev] Mapbender 3.0.8 released 2019-04-12
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Apr 15 05:39:55 PDT 2019
Here is a history of that file being included in past release archives:
- 3.0.8: missing
- 3.0.7.7: included in /app/bootstrap.php.cache
- 3.0.6.3: included in /app/bootstrap.php.cache
- 3.0.6.2: included in /app/bootstrap.php.cache
- 3.0.6.1: included in /app/bootstrap.php.cache
- 3.0.5.3: included in /app/bootstrap.php.cache
-jeff
On 2019-04-15 9:00 AM, Jeff McKenna wrote:
> For the record here is the new error with 3.0.8:
> Warning:
> require_once(C:\ms4w\apps\mapbender-starter-3.0.8\application\web/../app/bootstrap.php.cache):
> failed to open stream: No such file or directory in
> C:\ms4w\apps\mapbender-starter-3.0.8\application\web\app.php on line 6
> Fatal error: require_once(): Failed opening required
> 'C:\ms4w\apps\mapbender-starter-3.0.8\application\web/../app/bootstrap.php.cache'
> (include_path='.;\ms4w\Apache\php') in
> -jeff
> On 2019-04-15 8:45 AM, Jeff McKenna wrote:
>> For example: mapbender3-starter-3.0.7.7.zip contained that missing
>> file (which I realize is not under version control, but was packaged
>> in previous releases).
>> I have never had to run that command in any previous release. I also
>> notice that that command is not part of the Mapbender installation
>> documentation.
>> So my point is, something has changed with that 3.0.8 archive.
>> -jeff
>> On 2019-04-15 5:31 AM, Rolf Neuberger wrote:
>>> This is generated code. It's not under version control.
>>> The file is automatically generated by the bootstrap script in the
>>> project root, and implicitly also every time a compser package is
>>> installed or updated.
>>> You can explicitly trigger just the rebuild with a shell command:
>>> application$ bin/composer run build-bootstrap
>>> HTH,
>>> -Rolf
>>> On 12.04.19 14:38, Jeff McKenna wrote:
>>>> The release tags are missing a required file /app/bootstrap.php.cache
>>>> -jeff
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
More information about the Mapbender_dev
