[Mapbender-dev] Mapbender 3.0.8 released 2019-04-12
Rolf Neuberger
Rolf.Neuberger at wheregroup.com
Mon Apr 15 05:50:35 PDT 2019
Hi again Jeff,
regarding the zip archives, we had some unfinshed packaging work on
Friday, and going by the time stamps, it seems you caught an earlier
version of the download where the build hadn't run properly.
The updated zip package now available from
https://mapbender.org/download does contain the bootstrap.php.cache file
you're missing. Please download again.
The package has been regenerated on Friday 15:42 German summer time.
Sorry for the inconvenience.
On 15.04.19 14:39, Jeff McKenna wrote:
> Here is a history of that file being included in past release archives:
> - 3.0.8: missing
> - 3.0.7.7: included in /app/bootstrap.php.cache
> - 3.0.6.3: included in /app/bootstrap.php.cache
> - 3.0.6.2: included in /app/bootstrap.php.cache
> - 3.0.6.1: included in /app/bootstrap.php.cache
> - 3.0.5.3: included in /app/bootstrap.php.cache
> -jeff
> On 2019-04-15 9:00 AM, Jeff McKenna wrote:
>> For the record here is the new error with 3.0.8:
>> Warning:
>> require_once(C:\ms4w\apps\mapbender-starter-3.0.8\application\web/../app/bootstrap.php.cache):
>> failed to open stream: No such file or directory in
>> C:\ms4w\apps\mapbender-starter-3.0.8\application\web\app.php on line 6
>> Fatal error: require_once(): Failed opening required
>> 'C:\ms4w\apps\mapbender-starter-3.0.8\application\web/../app/bootstrap.php.cache'
>> (include_path='.;\ms4w\Apache\php') in
>> -jeff
>> On 2019-04-15 8:45 AM, Jeff McKenna wrote:
>>> For example: mapbender3-starter-3.0.7.7.zip contained that missing
>>> file (which I realize is not under version control, but was packaged
>>> in previous releases).
>>> I have never had to run that command in any previous release. I also
>>> notice that that command is not part of the Mapbender installation
>>> documentation.
>>> So my point is, something has changed with that 3.0.8 archive.
>>> -jeff
>>> On 2019-04-15 5:31 AM, Rolf Neuberger wrote:
>>>> This is generated code. It's not under version control.
>>>> The file is automatically generated by the bootstrap script in the
>>>> project root, and implicitly also every time a compser package is
>>>> installed or updated.
>>>> You can explicitly trigger just the rebuild with a shell command:
>>>> application$ bin/composer run build-bootstrap
>>>> HTH,
>>>> -Rolf
>>>> On 12.04.19 14:38, Jeff McKenna wrote:
>>>>> The release tags are missing a required file /app/bootstrap.php.cache
>>>>> -jeff
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
Rolf Neuberger
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 0
Fax: +49 (0)228 / 90 90 38 - 11
rolf.neuberger at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
