[Mapbender-dev] Mapbender 3.0.8 released 2019-04-12
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Apr 15 05:55:33 PDT 2019
Hi Rolf,
No problem I definitely understand. Thanks, will re-download.
-jeff
On 2019-04-15 9:50 AM, Rolf Neuberger wrote:
> Hi again Jeff,
> regarding the zip archives, we had some unfinshed packaging work on
> Friday, and going by the time stamps, it seems you caught an earlier
> version of the download where the build hadn't run properly.
> The updated zip package now available from
> https://mapbender.org/download does contain the bootstrap.php.cache file
> you're missing. Please download again.
> The package has been regenerated on Friday 15:42 German summer time.
> Sorry for the inconvenience.
> On 15.04.19 14:39, Jeff McKenna wrote:
>> Here is a history of that file being included in past release archives:
>> - 3.0.8: missing
>> - 3.0.7.7: included in /app/bootstrap.php.cache
>> - 3.0.6.3: included in /app/bootstrap.php.cache
>> - 3.0.6.2: included in /app/bootstrap.php.cache
>> - 3.0.6.1: included in /app/bootstrap.php.cache
>> - 3.0.5.3: included in /app/bootstrap.php.cache
>> -jeff
>> On 2019-04-15 9:00 AM, Jeff McKenna wrote:
>>> For the record here is the new error with 3.0.8:
>>> Warning:
>>> require_once(C:\ms4w\apps\mapbender-starter-3.0.8\application\web/../app/bootstrap.php.cache):
>>> failed to open stream: No such file or directory in
>>> C:\ms4w\apps\mapbender-starter-3.0.8\application\web\app.php on line 6
>>> Fatal error: require_once(): Failed opening required
>>> 'C:\ms4w\apps\mapbender-starter-3.0.8\application\web/../app/bootstrap.php.cache'
>>> (include_path='.;\ms4w\Apache\php') in
>>> -jeff
>>> On 2019-04-15 8:45 AM, Jeff McKenna wrote:
>>>> For example: mapbender3-starter-3.0.7.7.zip contained that missing
>>>> file (which I realize is not under version control, but was packaged
>>>> in previous releases).
>>>> I have never had to run that command in any previous release. I
>>>> also notice that that command is not part of the Mapbender
>>>> installation documentation.
>>>> So my point is, something has changed with that 3.0.8 archive.
>>>> -jeff
>>>> On 2019-04-15 5:31 AM, Rolf Neuberger wrote:
>>>>> This is generated code. It's not under version control.
>>>>> The file is automatically generated by the bootstrap script in the
>>>>> project root, and implicitly also every time a compser package is
>>>>> installed or updated.
>>>>> You can explicitly trigger just the rebuild with a shell command:
>>>>> application$ bin/composer run build-bootstrap
>>>>> HTH,
>>>>> -Rolf
>>>>> On 12.04.19 14:38, Jeff McKenna wrote:
>>>>>> The release tags are missing a required file /app/bootstrap.php.cache
>>>>>> -jeff
>>> Mapbender_dev mailing list
>>> Mapbender_dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
More information about the Mapbender_dev
