[Mapbender-dev] Mapbender 3.0.8 released 2019-04-12
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Tue Apr 16 23:37:46 PDT 2019
Hello Jeff,
thanks for supporting the Mapbender project.
Looking forward to have 3.0.8 on MS4W :)
Feedback from our last Winterschool: Some participants wanted to use the
stack on their windows machines (instead of OSGeoLive). It was so easy
to setup Mapbender & MapServer with MS4W. Great! They were impressed.
Thanks for providing MS4W!
https://ms4w.com/
Astrid
Am 2019-04-15 14:55, schrieb Jeff McKenna:
> Hi Rolf,
> No problem I definitely understand.  Thanks, will re-download.
> -jeff
> On 2019-04-15 9:50 AM, Rolf Neuberger wrote:
>> Hi again Jeff,
>> regarding the zip archives, we had some unfinshed packaging work on
>> Friday, and going by the time stamps, it seems you caught an earlier
>> version of the download where the build hadn't run properly.
>> The updated zip package now available from
>> https://mapbender.org/download does contain the bootstrap.php.cache
>> file you're missing. Please download again.
>> The package has been regenerated on Friday 15:42 German summer time.
>> Sorry for the inconvenience.
>> On 15.04.19 14:39, Jeff McKenna wrote:
>>> Here is a history of that file being included in past release
>>> archives:
>>> - 3.0.8: missing
>>> - 3.0.7.7: included in /app/bootstrap.php.cache
>>> - 3.0.6.3: included in /app/bootstrap.php.cache
>>> - 3.0.6.2: included in /app/bootstrap.php.cache
>>> - 3.0.6.1: included in /app/bootstrap.php.cache
>>> - 3.0.5.3: included in /app/bootstrap.php.cache
>>> -jeff
>>> On 2019-04-15 9:00 AM, Jeff McKenna wrote:
>>>> For the record here is the new error with 3.0.8:
>>>> Warning:
>>>> require_once(C:\ms4w\apps\mapbender-starter-3.0.8\application\web/../app/bootstrap.php.cache):
>>>> failed to open stream: No such file or directory in
>>>> C:\ms4w\apps\mapbender-starter-3.0.8\application\web\app.php on line
>>>> 6
>>>> Fatal error: require_once(): Failed opening required
>>>> 'C:\ms4w\apps\mapbender-starter-3.0.8\application\web/../app/bootstrap.php.cache'
>>>> (include_path='.;\ms4w\Apache\php') in
>>>> 6
>>>> -jeff
>>>> On 2019-04-15 8:45 AM, Jeff McKenna wrote:
>>>>> For example: mapbender3-starter-3.0.7.7.zip contained that missing
>>>>> file (which I realize is not under version control, but was
>>>>> packaged in previous releases).
>>>>> I have never had to run that command in any previous release.  I
>>>>> also notice that that command is not part of the Mapbender
>>>>> installation documentation.
>>>>> So my point is, something has changed with that 3.0.8 archive.
>>>>> -jeff
>>>>> On 2019-04-15 5:31 AM, Rolf Neuberger wrote:
>>>>>> This is generated code. It's not under version control.
>>>>>> The file is automatically generated by the bootstrap script in the
>>>>>> project root, and implicitly also every time a compser package is
>>>>>> installed or updated.
>>>>>> You can explicitly trigger just the rebuild with a shell command:
>>>>>> application$ bin/composer run build-bootstrap
>>>>>> HTH,
>>>>>> -Rolf
>>>>>> On 12.04.19 14:38, Jeff McKenna wrote:
>>>>>>> The release tags are missing a required file
>>>>>>> -jeff
>>>> _______________________________________________
>>>> Mapbender_dev mailing list
>>>> Mapbender_dev at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
   Astrid Emde
   WhereGroup GmbH & Co.KG
   Eifelstraße 7
   53119 Bonn
   Germany
   Fon: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
