[Mapbender-dev] Mapbender 3.0.8 released 2019-04-12
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Apr 17 11:17:27 PDT 2019
Thanks for the great feedback Astrid!
The MS4W 4.0.0 installer now includes Mapbender 3.0.8 https://ms4w.com
Thank you for using MS4W.
"MS4W: open doors as well as windows"
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2019-04-17 3:37 AM, Astrid Emde (WhereGroup) wrote:
> Hello Jeff,
> thanks for supporting the Mapbender project.
> Looking forward to have 3.0.8 on MS4W :)
> Feedback from our last Winterschool: Some participants wanted to use the
> stack on their windows machines (instead of OSGeoLive). It was so easy
> to setup Mapbender & MapServer with MS4W. Great! They were impressed.
> Thanks for providing MS4W!
> https://ms4w.com/
> Astrid
> Am 2019-04-15 14:55, schrieb Jeff McKenna:
>> Hi Rolf,
>> No problem I definitely understand. Thanks, will re-download.
>> -jeff
>> On 2019-04-15 9:50 AM, Rolf Neuberger wrote:
>>> Hi again Jeff,
>>> regarding the zip archives, we had some unfinshed packaging work on
>>> Friday, and going by the time stamps, it seems you caught an earlier
>>> version of the download where the build hadn't run properly.
>>> The updated zip package now available from
>>> https://mapbender.org/download does contain the bootstrap.php.cache
>>> file you're missing. Please download again.
>>> The package has been regenerated on Friday 15:42 German summer time.
>>> Sorry for the inconvenience.
>>> On 15.04.19 14:39, Jeff McKenna wrote:
>>>> Here is a history of that file being included in past release archives:
>>>> - 3.0.8: missing
>>>> - 3.0.7.7: included in /app/bootstrap.php.cache
>>>> - 3.0.6.3: included in /app/bootstrap.php.cache
>>>> - 3.0.6.2: included in /app/bootstrap.php.cache
>>>> - 3.0.6.1: included in /app/bootstrap.php.cache
>>>> - 3.0.5.3: included in /app/bootstrap.php.cache
>>>> -jeff
>>>> On 2019-04-15 9:00 AM, Jeff McKenna wrote:
>>>>> For the record here is the new error with 3.0.8:
>>>>> Warning:
>>>>> require_once(C:\ms4w\apps\mapbender-starter-3.0.8\application\web/../app/bootstrap.php.cache):
>>>>> failed to open stream: No such file or directory in
>>>>> C:\ms4w\apps\mapbender-starter-3.0.8\application\web\app.php on line 6
>>>>> Fatal error: require_once(): Failed opening required
>>>>> 'C:\ms4w\apps\mapbender-starter-3.0.8\application\web/../app/bootstrap.php.cache'
>>>>> (include_path='.;\ms4w\Apache\php') in
>>>>> -jeff
>>>>> On 2019-04-15 8:45 AM, Jeff McKenna wrote:
>>>>>> For example: mapbender3-starter-3.0.7.7.zip contained that missing
>>>>>> file (which I realize is not under version control, but was
>>>>>> packaged in previous releases).
>>>>>> I have never had to run that command in any previous release. I
>>>>>> also notice that that command is not part of the Mapbender
>>>>>> installation documentation.
>>>>>> So my point is, something has changed with that 3.0.8 archive.
>>>>>> -jeff
>>>>>> On 2019-04-15 5:31 AM, Rolf Neuberger wrote:
>>>>>>> This is generated code. It's not under version control.
>>>>>>> The file is automatically generated by the bootstrap script in
>>>>>>> the project root, and implicitly also every time a compser
>>>>>>> package is installed or updated.
>>>>>>> You can explicitly trigger just the rebuild with a shell command:
>>>>>>> application$ bin/composer run build-bootstrap
>>>>>>> HTH,
>>>>>>> -Rolf
>>>>>>> On 12.04.19 14:38, Jeff McKenna wrote:
>>>>>>>> The release tags are missing a required file
>>>>>>>> -jeff
More information about the Mapbender_dev
