[Mapbender-dev] Mapbender 3.0.8 released 2019-04-12
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Wed Apr 17 22:14:11 PDT 2019
Wow! Thanks a lot.
Great news!
Astrid
Am 2019-04-17 20:17, schrieb Jeff McKenna:
> Thanks for the great feedback Astrid!
> The MS4W 4.0.0 installer now includes Mapbender 3.0.8  https://ms4w.com
> Thank you for using MS4W.
> "MS4W: open doors as well as windows"
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> https://gatewaygeomatics.com/
> On 2019-04-17 3:37 AM, Astrid Emde (WhereGroup) wrote:
>> Hello Jeff,
>> thanks for supporting the Mapbender project.
>> Looking forward to have 3.0.8 on MS4W :)
>> Feedback from our last Winterschool: Some participants wanted to use
>> the stack on their windows machines (instead of OSGeoLive). It was so
>> easy to setup Mapbender & MapServer with MS4W. Great! They were
>> impressed. Thanks for providing MS4W!
>> https://ms4w.com/
>> Astrid
>> Am 2019-04-15 14:55, schrieb Jeff McKenna:
>>> Hi Rolf,
>>> No problem I definitely understand.  Thanks, will re-download.
>>> -jeff
>>> On 2019-04-15 9:50 AM, Rolf Neuberger wrote:
>>>> Hi again Jeff,
>>>> regarding the zip archives, we had some unfinshed packaging work on
>>>> Friday, and going by the time stamps, it seems you caught an earlier
>>>> version of the download where the build hadn't run properly.
>>>> The updated zip package now available from
>>>> https://mapbender.org/download does contain the bootstrap.php.cache
>>>> file you're missing. Please download again.
>>>> The package has been regenerated on Friday 15:42 German summer time.
>>>> Sorry for the inconvenience.
>>>> On 15.04.19 14:39, Jeff McKenna wrote:
>>>>> Here is a history of that file being included in past release
>>>>> archives:
>>>>> - 3.0.8: missing
>>>>> - 3.0.7.7: included in /app/bootstrap.php.cache
>>>>> - 3.0.6.3: included in /app/bootstrap.php.cache
>>>>> - 3.0.6.2: included in /app/bootstrap.php.cache
>>>>> - 3.0.6.1: included in /app/bootstrap.php.cache
>>>>> - 3.0.5.3: included in /app/bootstrap.php.cache
>>>>> -jeff
>>>>> On 2019-04-15 9:00 AM, Jeff McKenna wrote:
>>>>>> For the record here is the new error with 3.0.8:
>>>>>> Warning:
>>>>>> require_once(C:\ms4w\apps\mapbender-starter-3.0.8\application\web/../app/bootstrap.php.cache):
>>>>>> failed to open stream: No such file or directory in
>>>>>> C:\ms4w\apps\mapbender-starter-3.0.8\application\web\app.php on
>>>>>> line 6
>>>>>> Fatal error: require_once(): Failed opening required
>>>>>> 'C:\ms4w\apps\mapbender-starter-3.0.8\application\web/../app/bootstrap.php.cache'
>>>>>> (include_path='.;\ms4w\Apache\php') in
>>>>>> line 6
>>>>>> -jeff
>>>>>> On 2019-04-15 8:45 AM, Jeff McKenna wrote:
>>>>>>> For example: mapbender3-starter-3.0.7.7.zip contained that
>>>>>>> missing file (which I realize is not under version control, but
>>>>>>> was packaged in previous releases).
>>>>>>> I have never had to run that command in any previous release.  I
>>>>>>> also notice that that command is not part of the Mapbender
>>>>>>> installation documentation.
>>>>>>> So my point is, something has changed with that 3.0.8 archive.
>>>>>>> -jeff
>>>>>>> On 2019-04-15 5:31 AM, Rolf Neuberger wrote:
>>>>>>>> This is generated code. It's not under version control.
>>>>>>>> The file is automatically generated by the bootstrap script in
>>>>>>>> the project root, and implicitly also every time a compser
>>>>>>>> package is installed or updated.
>>>>>>>> You can explicitly trigger just the rebuild with a shell
>>>>>>>> command:
>>>>>>>> application$ bin/composer run build-bootstrap
>>>>>>>> HTH,
>>>>>>>> -Rolf
>>>>>>>> On 12.04.19 14:38, Jeff McKenna wrote:
>>>>>>>>> The release tags are missing a required file
>>>>>>>>> -jeff
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
   Astrid Emde
   WhereGroup GmbH & Co.KG
   Eifelstraße 7
   53119 Bonn
   Germany
   Fon: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
