[Mapbender-dev] Mapbender 3.0.8 released 2019-04-12
eric rasamoelina eric eerriicc8181 at gmail.com
Sat Apr 27 03:31:27 PDT 2019
hello,please how  to change the server logo and add the new function same
as statictics, login, ect,,
thank you
Le jeu. 18 avr. 2019 à 08:14, Astrid Emde (WhereGroup) <
astrid.emde at wheregroup.com> a écrit :
> Wow! Thanks a lot.
> Great news!
> Astrid
> Am 2019-04-17 20:17, schrieb Jeff McKenna:
> > Thanks for the great feedback Astrid!
> > The MS4W 4.0.0 installer now includes Mapbender 3.0.8  https://ms4w.com
> > Thank you for using MS4W.
> > "MS4W: open doors as well as windows"
> > -jeff
> > Jeff McKenna
> > MapServer Consulting and Training Services
> > https://gatewaygeomatics.com/
> > On 2019-04-17 3:37 AM, Astrid Emde (WhereGroup) wrote:
> >> Hello Jeff,
> >> thanks for supporting the Mapbender project.
> >> Looking forward to have 3.0.8 on MS4W :)
> >> Feedback from our last Winterschool: Some participants wanted to use
> >> the stack on their windows machines (instead of OSGeoLive). It was so
> >> easy to setup Mapbender & MapServer with MS4W. Great! They were
> >> impressed. Thanks for providing MS4W!
> >> https://ms4w.com/
> >> Astrid
> >> Am 2019-04-15 14:55, schrieb Jeff McKenna:
> >>> Hi Rolf,
> >>> No problem I definitely understand.  Thanks, will re-download.
> >>> -jeff
> >>> On 2019-04-15 9:50 AM, Rolf Neuberger wrote:
> >>>> Hi again Jeff,
> >>>> regarding the zip archives, we had some unfinshed packaging work on
> >>>> Friday, and going by the time stamps, it seems you caught an earlier
> >>>> version of the download where the build hadn't run properly.
> >>>> The updated zip package now available from
> >>>> https://mapbender.org/download does contain the bootstrap.php.cache
> >>>> file you're missing. Please download again.
> >>>> The package has been regenerated on Friday 15:42 German summer time.
> >>>> Sorry for the inconvenience.
> >>>> On 15.04.19 14:39, Jeff McKenna wrote:
> >>>>> Here is a history of that file being included in past release
> >>>>> archives:
> >>>>> - 3.0.8: missing
> >>>>> - 3.0.7.7: included in /app/bootstrap.php.cache
> >>>>> - 3.0.6.3: included in /app/bootstrap.php.cache
> >>>>> - 3.0.6.2: included in /app/bootstrap.php.cache
> >>>>> - 3.0.6.1: included in /app/bootstrap.php.cache
> >>>>> - 3.0.5.3: included in /app/bootstrap.php.cache
> >>>>> -jeff
> >>>>> On 2019-04-15 9:00 AM, Jeff McKenna wrote:
> >>>>>> For the record here is the new error with 3.0.8:
> >>>>>> Warning:
> require_once(C:\ms4w\apps\mapbender-starter-3.0.8\application\web/../app/bootstrap.php.cache):
> >>>>>> failed to open stream: No such file or directory in
> >>>>>> C:\ms4w\apps\mapbender-starter-3.0.8\application\web\app.php on
> >>>>>> line 6
> >>>>>> Fatal error: require_once(): Failed opening required
> 'C:\ms4w\apps\mapbender-starter-3.0.8\application\web/../app/bootstrap.php.cache'
> >>>>>> (include_path='.;\ms4w\Apache\php') in
> >>>>>> line 6
> >>>>>> -jeff
> >>>>>> On 2019-04-15 8:45 AM, Jeff McKenna wrote:
> >>>>>>> For example: mapbender3-starter-3.0.7.7.zip contained that
> >>>>>>> missing file (which I realize is not under version control, but
> >>>>>>> was packaged in previous releases).
> >>>>>>> I have never had to run that command in any previous release.  I
> >>>>>>> also notice that that command is not part of the Mapbender
> >>>>>>> installation documentation.
> >>>>>>> So my point is, something has changed with that 3.0.8 archive.
> >>>>>>> -jeff
> >>>>>>> On 2019-04-15 5:31 AM, Rolf Neuberger wrote:
> >>>>>>>> This is generated code. It's not under version control.
> >>>>>>>> The file is automatically generated by the bootstrap script in
> >>>>>>>> the project root, and implicitly also every time a compser
> >>>>>>>> package is installed or updated.
> >>>>>>>> You can explicitly trigger just the rebuild with a shell
> >>>>>>>> command:
> >>>>>>>> application$ bin/composer run build-bootstrap
> >>>>>>>> HTH,
> >>>>>>>> -Rolf
> >>>>>>>> On 12.04.19 14:38, Jeff McKenna wrote:
> >>>>>>>>> The release tags are missing a required file
> >>>>>>>>> -jeff
> > Mapbender_dev mailing list
> > Mapbender_dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/mapbender_dev
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> Aufwind durch Wissen!
> Qualifizierte Open-Source-Schulungen
> bei der www.foss-academy.com
>    Astrid Emde
>    WhereGroup GmbH & Co.KG
>    Eifelstraße 7
>    53119 Bonn
>    Germany
>    Fon: +49(0)228 90 90 38 - 22
>    Fax: +49(0)228 90 90 38 - 11
>    www.wheregroup.com
>    Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
URL: <http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20190427/961db6f4/attachment.html>
More information about the Mapbender_dev mailing list
