[Mapbender-dev] Wrong link in online documentation
Frederik Haefker (WhereGroup) frederik.haefker at wheregroup.com
Mon Aug 26 06:04:20 PDT 2019
Hello Walter,
Thanks for the comment. We will correct the wrong URL as soon as possible.
For a quick reference: You can use the following URL [1]. You can find
this overview in the Mapbender documentation by searching for "history"
[2] .
Best Regards
Frederik Häfker
[1] https://doc.mapbender.org/en/versions.html?highlight=history
[2] https://doc.mapbender.org/
On 25.08.19 13:59, wambacher at posteo.de wrote:
> Hi,
> this link does not work on
> https://www.mapbender.org/?q=en/what-is-mapbender
> *Version history of Mapbender
> You will find the version history in the Mapbender documentation
> <http://doc.mapbender.org/book/versions.html>*.
> Regards
> walter
> btw: need this info to maintain the "OSM Software Watchlist", which
> represents a compilation of many software products that are important
> in OpenStreetMap environment. Mapbender will be added asap - if i can
> find the release infos.
> My projects:
> Admin Boundaries of the World <https://wambachers-osm.website/boundaries>
> Missing Boundaries
> <https://wambachers-osm.website/index.php/projekte/internationale-administrative-grenzen/missing-boundaries>
> Emergency Map <https://wambachers-osm.website/emergency>
> Postal Code Map (Germany only) <https://wambachers-osm.website/plz>
> Fools (QA for zipcodes in Germany) <https://wambachers-osm.website/fools>
> Postcode Boundaries of Germany
> <https://wambachers-osm.website/pcoundaries>
> <https://wambachers-osm.website/index.php/osm-software-watchlist>
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
Kompaktkurs Aufbau einer GDI mit Open-Source-Software
FOSS Academy Sommerschule: 23. bis 27.09.2019
https://www.foss-academy.com/kompaktkurse.html
Frederik Häfker
Abteilungsleiter Projektmanagement und GIS-Consulting
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 21
Fax: +49 (0)228 / 90 90 38 - 11
Frederik.Haefker at wheregroup.com
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20190826/9e736f42/attachment.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20190826/9e736f42/attachment.sig>
More information about the Mapbender_dev mailing list
