[Mapbender-dev] (no subject)
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Wed Feb 27 22:55:01 PST 2019
Hello Eric,
it looks like Mapbender can't connect to your database.
Your config files look fine
your search database is: database2_name search_db
Did you try the app_dev.php mode?
http://your-server/mapbender/app_dev.php
It will offer you more details in the developer tools response
Also make sure that you empty the cache mapbender/app/cache as changes
in the config files are cached in productive mode.
Astrid
Am 2019-02-27 19:07, schrieb eric rasamoelina eric:
> Dear Mapbender community
> thank you very much!!
> If i open the application in a browser i receive the following error:
> Feature API query error.”<!DOCTYPE html>\n<html>\n <head>\n <meta
> charset=\”UTF-8\” />\n <titel>An Error Occured: Internal Server
> Error</titel>\n </head>\n <body>\n <h1>Oops! An Error Occurred</h1>\n
> <h2>The server returned a \”500 Internal Server Error\”.</h2>\n\n
> <div>\n Something is broken. Please let us know what you were doing
> when this error occurred.\n We will fix it as soon as possible. Sorry
> for any inconvenience caused.\n </div>\n </body>\n</html>\n”
> Down below, there are the parameters.yml and config.yml. Do anybody
> know how to solve these problems?
> Thank you for your help and best regards,
> Eric
> I've this script
> config.yml
> imports: - { resource: parameters.yml } - { resource: security.yml }
> framework: #esi: ~ translator: { fallback: %fallback_locale% } secret:
> %secret% router: resource: "%kernel.root_dir%/config/routing.yml"
> strict_requirements: %kernel.debug% form: true csrf_protection: true
> validation: { enable_annotations: true } templating: { engines:
> ['twig'] } #assets_version: SomeVersionScheme default_locale: %locale%
> session: cookie_httponly: true cookie_secure: %cookie_secure%
> cookie_lifetime: %cookie_lifetime% # Twig Configuration twig: debug:
> %kernel.debug% strict_variables: %kernel.debug% globals: fom: %fom%
> form: resources: - 'FOMCoreBundle:Form:fields.html.twig' # Assetic
> Configuration assetic: debug: %kernel.debug% use_controller: true
> filters: cssrewrite: ~ sass: ~ # Doctrine Configuration doctrine:
> dbal: default_connection: default connections: default: driver:
> "%database_driver%" host: "%database_host%" port: "%database_port%"
> dbname: "%database_name%" path: "%database_path%" user:
> "%database_user%" password: "%database_password%" #persistent: true
> (nodekomantena) charset: UTF8 logging: %kernel.debug% profiling:
> %kernel.debug% #second database search_db: driver:
> "%database2_driver%" host: "%database2_host%" port: "%database2_port%"
> dbname: "%database2_name%" path: "%database2_path%" user:
> "%database2_user%" password: "%database2_password%" charset: UTF8
> logging: "%kernel.debug%" profiling: "%kernel.debug%" orm:
> auto_generate_proxy_classes: %kernel.debug% auto_mapping: true #
> Swiftmailer Configuration swiftmailer: transport: %mailer_transport%
> host: %mailer_host% username: %mailer_user% password:
> %mailer_password% spool: { type: memory } # FOM Manager Configuration
> fom_manager: route_prefix: /manager # FOM User Configuration fom_user:
> selfregister: false reset_password: true max_registration_time: 1
> max_reset_time: 1 mail_from_address: wizard at oz.net mail_from_name:
> Wizard of Oz profile_entity: FOM\UserBundle\Entity\BasicProfile
> profile_formtype: FOM\UserBundle\Form\Type\BasicProfileType
> profile_template: FOMUserBundle:User:basic_profile.html.twig
> self_registration_groups: - Self Registered - Demo Group # Allow to
> create user log table on the fly if the table doesn't exits. #
> Default: true auto_create_log_table: false # Time between to check
> login tries login_check_log_time: "-5 minutes" # Login attemps before
> delay starts login_attempts_before_delay: 3 # Login delay after all
> attemps are failed login_delay_after_fail: 5 # Seconds # OWSProxy
> Configuration ows_proxy3_core: logging: %ows_proxy3_logging%
> obfuscate_client_ip: %ows_proxy3_obfuscate_client_ip% proxy: host:
> %ows_proxy3_host% port: %ows_proxy3_port% connecttimeout:
> %ows_proxy3_connecttimeout% timeout: %ows_proxy3_timeout% user:
> %ows_proxy3_user% password: %ows_proxy3_password% checkssl: true
> noproxy: %ows_proxy3_noproxy% # Mapbender Configuration
> mapbender_core: ~
> parameters.yml
> parameters: # database-connection "default" database_driver: pdo_pgsql
> database_host: localhost database_port: 5432 database_name:
> JDElectricite database_path: ~ database_user: postgres
> database_password: post # database-connection "search_db"
> database2_driver: pdo_pgsql database2_host: localhost database2_port:
> 5432 database2_name: search_db database2_path: ~ database2_user:
> postgres database2_password: post
>  #database_driver: pdo_sqlite #database_host: ~ #database_port: ~
> #database_name: ~ #database_path: %kernel.root_dir%/db/demo.sqlite
> #database_user: ~ #database_password: ~ mailer_transport: smtp
> mailer_host: localhost mailer_user: ~ mailer_password: ~ # locale en,
> de, it, es, ru, nl, pt are available fallback_locale: en locale: en
> secret: ThisTokenIsNotSoSecretChangeIt fom: server_name: Mapbender3
> server_version: 3.0.6.3 server_logo:
> bundles/mapbendercore/image/logo_mb3.png # framework :
> http://symfony.com/doc/2.8/reference/configuration/framework.html#cookie-lifetime
> cookie_secure: false cookie_lifetime: 3600 # OWSProxy Configuration
> ows_proxy3_logging: false ows_proxy3_obfuscate_client_ip: true
> ows_proxy3_host: ~ ows_proxy3_port: ~ ows_proxy3_connecttimeout: 60
> ows_proxy3_timeout: 90 ows_proxy3_user: ~ ows_proxy3_password: ~
> ows_proxy3_noproxy: ~
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
FOSS Academy Kompaktkurs "Winterschule 2019"
Grundwissen zum Aufbau von Geodateninfrastrukturen mit
Open-Source-Software https://foss-academy.com/kompaktkurse
   Astrid Emde
   WhereGroup GmbH & Co.KG
   Eifelstraße 7
   53119 Bonn
   Germany
   Fon: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
