[Mapbender-dev] (no subject)
eric rasamoelina eric
eerriicc8181 at gmail.com
Wed Mar 20 11:10:29 PDT 2019
Please !, who upload pictures by digitize and show it in popup!?, Please
help me!
On Mar 3, 2019 9:37 PM, "eric rasamoelina eric" <eerriicc8181 at gmail.com>
wrote:
> Thank so much for your advanced!,,,,, If I open
> https://localhost/mapbender/app_dev.php/ ,, I see :
> InvalidArgumentException in YamlFileLoader.php line 366
> The file "c:\ms4w\apps\mapbender3-starter-3.0.7.7\app/
> config/config_dev.yml" does not contain valid YAML.
> On Feb 28, 2019 9:55 AM, "Astrid Emde (WhereGroup)" <
> astrid.emde at wheregroup.com> wrote:
>> Hello Eric,
>> it looks like Mapbender can't connect to your database.
>> Your config files look fine
>> your search database is: database2_name search_db
>> Did you try the app_dev.php mode?
>> http://your-server/mapbender/app_dev.php
>> It will offer you more details in the developer tools response
>> Also make sure that you empty the cache mapbender/app/cache as changes in
>> the config files are cached in productive mode.
>> Astrid
>> Am 2019-02-27 19:07, schrieb eric rasamoelina eric:
>>> Dear Mapbender community
>>> thank you very much!!
>>> If i open the application in a browser i receive the following error:
>>> Feature API query error.”<!DOCTYPE html>\n<html>\n <head>\n <meta
>>> charset=\”UTF-8\” />\n <titel>An Error Occured: Internal Server
>>> Error</titel>\n </head>\n <body>\n <h1>Oops! An Error Occurred</h1>\n
>>> <h2>The server returned a \”500 Internal Server Error\”.</h2>\n\n
>>> <div>\n Something is broken. Please let us know what you were doing
>>> when this error occurred.\n We will fix it as soon as possible. Sorry
>>> for any inconvenience caused.\n </div>\n </body>\n</html>\n”
>>> Down below, there are the parameters.yml and config.yml. Do anybody
>>> know how to solve these problems?
>>> Thank you for your help and best regards,
>>> Eric
>>> I've this script
>>> config.yml
>>> imports: - { resource: parameters.yml } - { resource: security.yml }
>>> framework: #esi: ~ translator: { fallback: %fallback_locale% } secret:
>>> %secret% router: resource: "%kernel.root_dir%/config/routing.yml"
>>> strict_requirements: %kernel.debug% form: true csrf_protection: true
>>> validation: { enable_annotations: true } templating: { engines:
>>> ['twig'] } #assets_version: SomeVersionScheme default_locale: %locale%
>>> session: cookie_httponly: true cookie_secure: %cookie_secure%
>>> cookie_lifetime: %cookie_lifetime% # Twig Configuration twig: debug:
>>> %kernel.debug% strict_variables: %kernel.debug% globals: fom: %fom%
>>> form: resources: - 'FOMCoreBundle:Form:fields.html.twig' # Assetic
>>> Configuration assetic: debug: %kernel.debug% use_controller: true
>>> filters: cssrewrite: ~ sass: ~ # Doctrine Configuration doctrine:
>>> dbal: default_connection: default connections: default: driver:
>>> "%database_driver%" host: "%database_host%" port: "%database_port%"
>>> dbname: "%database_name%" path: "%database_path%" user:
>>> "%database_user%" password: "%database_password%" #persistent: true
>>> (nodekomantena) charset: UTF8 logging: %kernel.debug% profiling:
>>> %kernel.debug% #second database search_db: driver:
>>> "%database2_driver%" host: "%database2_host%" port: "%database2_port%"
>>> dbname: "%database2_name%" path: "%database2_path%" user:
>>> "%database2_user%" password: "%database2_password%" charset: UTF8
>>> logging: "%kernel.debug%" profiling: "%kernel.debug%" orm:
>>> auto_generate_proxy_classes: %kernel.debug% auto_mapping: true #
>>> Swiftmailer Configuration swiftmailer: transport: %mailer_transport%
>>> host: %mailer_host% username: %mailer_user% password:
>>> %mailer_password% spool: { type: memory } # FOM Manager Configuration
>>> fom_manager: route_prefix: /manager # FOM User Configuration fom_user:
>>> selfregister: false reset_password: true max_registration_time: 1
>>> max_reset_time: 1 mail_from_address: wizard at oz.net mail_from_name:
>>> Wizard of Oz profile_entity: FOM\UserBundle\Entity\BasicProfile
>>> profile_formtype: FOM\UserBundle\Form\Type\BasicProfileType
>>> profile_template: FOMUserBundle:User:basic_profile.html.twig
>>> self_registration_groups: - Self Registered - Demo Group # Allow to
>>> create user log table on the fly if the table doesn't exits. #
>>> Default: true auto_create_log_table: false # Time between to check
>>> login tries login_check_log_time: "-5 minutes" # Login attemps before
>>> delay starts login_attempts_before_delay: 3 # Login delay after all
>>> attemps are failed login_delay_after_fail: 5 # Seconds # OWSProxy
>>> Configuration ows_proxy3_core: logging: %ows_proxy3_logging%
>>> obfuscate_client_ip: %ows_proxy3_obfuscate_client_ip% proxy: host:
>>> %ows_proxy3_host% port: %ows_proxy3_port% connecttimeout:
>>> %ows_proxy3_connecttimeout% timeout: %ows_proxy3_timeout% user:
>>> %ows_proxy3_user% password: %ows_proxy3_password% checkssl: true
>>> noproxy: %ows_proxy3_noproxy% # Mapbender Configuration
>>> mapbender_core: ~
>>> parameters.yml
>>> parameters: # database-connection "default" database_driver: pdo_pgsql
>>> database_host: localhost database_port: 5432 database_name:
>>> JDElectricite database_path: ~ database_user: postgres
>>> database_password: post # database-connection "search_db"
>>> database2_driver: pdo_pgsql database2_host: localhost database2_port:
>>> 5432 database2_name: search_db database2_path: ~ database2_user:
>>> postgres database2_password: post
>>> #database_driver: pdo_sqlite #database_host: ~ #database_port: ~
>>> #database_name: ~ #database_path: %kernel.root_dir%/db/demo.sqlite
>>> #database_user: ~ #database_password: ~ mailer_transport: smtp
>>> mailer_host: localhost mailer_user: ~ mailer_password: ~ # locale en,
>>> de, it, es, ru, nl, pt are available fallback_locale: en locale: en
>>> secret: ThisTokenIsNotSoSecretChangeIt fom: server_name: Mapbender3
>>> server_version: 3.0.6.3 server_logo:
>>> bundles/mapbendercore/image/logo_mb3.png # framework :
>>> http://symfony.com/doc/2.8/reference/configuration/framework
>>> .html#cookie-lifetime
>>> cookie_secure: false cookie_lifetime: 3600 # OWSProxy Configuration
>>> ows_proxy3_logging: false ows_proxy3_obfuscate_client_ip: true
>>> ows_proxy3_host: ~ ows_proxy3_port: ~ ows_proxy3_connecttimeout: 60
>>> ows_proxy3_timeout: 90 ows_proxy3_user: ~ ows_proxy3_password: ~
>>> ows_proxy3_noproxy: ~
>>> Mapbender_dev mailing list
>>> Mapbender_dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
>> Mit freundlichen Grüßen
>> Astrid Emde
>> GIS-Consultant
>> FOSS Academy Kompaktkurs "Winterschule 2019"
>> Grundwissen zum Aufbau von Geodateninfrastrukturen mit
>> Open-Source-Software https://foss-academy.com/kompaktkurse
>> Astrid Emde
>> WhereGroup GmbH & Co.KG
>> Eifelstraße 7
>> 53119 Bonn
>> Germany
>> Fon: +49(0)228 90 90 38 - 22
>> Fax: +49(0)228 90 90 38 - 11
>> www.wheregroup.com
>> Folgen Sie der WhereGroup auf twitter:
>> http://twitter.com/WhereGroup_com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Olaf Knopp, Peter Stamm
URL: <http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20190320/c03afeb9/attachment.html>
More information about the Mapbender_dev
