[Mapbender-dev] Mapbender 3.0.8 released 2019-04-12
eric rasamoelina eric eerriicc8181 at gmail.com
Tue May 21 23:51:10 PDT 2019
hello , when I creat the element Mapklick ,I see the following error,
ERROR - Uncaught PHP Exception
Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "The
application can not be found." at
D:\ms4w\apps\mapbender3-starter-3.0.7.7\mapbender\src\Mapbender\CoreBundle\Controller\ApplicationController.php
line 213
can you help me!!
Le sam. 27 avr. 2019 à 13:31, eric rasamoelina eric <eerriicc8181 at gmail.com>
a écrit :
> hello,please how  to change the server logo and add the new function same
> as statictics, login, ect,,
> thank you
> Le jeu. 18 avr. 2019 à 08:14, Astrid Emde (WhereGroup) <
> astrid.emde at wheregroup.com> a écrit :
>> Wow! Thanks a lot.
>> Great news!
>> Astrid
>> Am 2019-04-17 20:17, schrieb Jeff McKenna:
>> > Thanks for the great feedback Astrid!
>> > The MS4W 4.0.0 installer now includes Mapbender 3.0.8  https://ms4w.com
>> > Thank you for using MS4W.
>> > "MS4W: open doors as well as windows"
>> > -jeff
>> > Jeff McKenna
>> > MapServer Consulting and Training Services
>> > https://gatewaygeomatics.com/
>> > On 2019-04-17 3:37 AM, Astrid Emde (WhereGroup) wrote:
>> >> Hello Jeff,
>> >> thanks for supporting the Mapbender project.
>> >> Looking forward to have 3.0.8 on MS4W :)
>> >> Feedback from our last Winterschool: Some participants wanted to use
>> >> the stack on their windows machines (instead of OSGeoLive). It was so
>> >> easy to setup Mapbender & MapServer with MS4W. Great! They were
>> >> impressed. Thanks for providing MS4W!
>> >> https://ms4w.com/
>> >> Astrid
>> >> Am 2019-04-15 14:55, schrieb Jeff McKenna:
>> >>> Hi Rolf,
>> >>> No problem I definitely understand.  Thanks, will re-download.
>> >>> -jeff
>> >>> On 2019-04-15 9:50 AM, Rolf Neuberger wrote:
>> >>>> Hi again Jeff,
>> >>>> regarding the zip archives, we had some unfinshed packaging work on
>> >>>> Friday, and going by the time stamps, it seems you caught an earlier
>> >>>> version of the download where the build hadn't run properly.
>> >>>> The updated zip package now available from
>> >>>> https://mapbender.org/download does contain the bootstrap.php.cache
>> >>>> file you're missing. Please download again.
>> >>>> The package has been regenerated on Friday 15:42 German summer time.
>> >>>> Sorry for the inconvenience.
>> >>>> On 15.04.19 14:39, Jeff McKenna wrote:
>> >>>>> Here is a history of that file being included in past release
>> >>>>> archives:
>> >>>>> - 3.0.8: missing
>> >>>>> - 3.0.7.7: included in /app/bootstrap.php.cache
>> >>>>> - 3.0.6.3: included in /app/bootstrap.php.cache
>> >>>>> - 3.0.6.2: included in /app/bootstrap.php.cache
>> >>>>> - 3.0.6.1: included in /app/bootstrap.php.cache
>> >>>>> - 3.0.5.3: included in /app/bootstrap.php.cache
>> >>>>> -jeff
>> >>>>> On 2019-04-15 9:00 AM, Jeff McKenna wrote:
>> >>>>>> For the record here is the new error with 3.0.8:
>> >>>>>> Warning:
>> require_once(C:\ms4w\apps\mapbender-starter-3.0.8\application\web/../app/bootstrap.php.cache):
>> >>>>>> failed to open stream: No such file or directory in
>> >>>>>> C:\ms4w\apps\mapbender-starter-3.0.8\application\web\app.php on
>> >>>>>> line 6
>> >>>>>> Fatal error: require_once(): Failed opening required
>> 'C:\ms4w\apps\mapbender-starter-3.0.8\application\web/../app/bootstrap.php.cache'
>> >>>>>> (include_path='.;\ms4w\Apache\php') in
>> >>>>>> line 6
>> >>>>>> -jeff
>> >>>>>> On 2019-04-15 8:45 AM, Jeff McKenna wrote:
>> >>>>>>> For example: mapbender3-starter-3.0.7.7.zip contained that
>> >>>>>>> missing file (which I realize is not under version control, but
>> >>>>>>> was packaged in previous releases).
>> >>>>>>> I have never had to run that command in any previous release.  I
>> >>>>>>> also notice that that command is not part of the Mapbender
>> >>>>>>> installation documentation.
>> >>>>>>> So my point is, something has changed with that 3.0.8 archive.
>> >>>>>>> -jeff
>> >>>>>>> On 2019-04-15 5:31 AM, Rolf Neuberger wrote:
>> >>>>>>>> This is generated code. It's not under version control.
>> >>>>>>>> The file is automatically generated by the bootstrap script in
>> >>>>>>>> the project root, and implicitly also every time a compser
>> >>>>>>>> package is installed or updated.
>> >>>>>>>> You can explicitly trigger just the rebuild with a shell
>> >>>>>>>> command:
>> >>>>>>>> application$ bin/composer run build-bootstrap
>> >>>>>>>> HTH,
>> >>>>>>>> -Rolf
>> >>>>>>>> On 12.04.19 14:38, Jeff McKenna wrote:
>> >>>>>>>>> The release tags are missing a required file
>> >>>>>>>>> -jeff
>> > _______________________________________________
>> > Mapbender_dev mailing list
>> > Mapbender_dev at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/mapbender_dev
>> Mit freundlichen Grüßen
>> Astrid Emde
>> GIS-Consultant
>> Aufwind durch Wissen!
>> Qualifizierte Open-Source-Schulungen
>> bei der www.foss-academy.com
>>    Astrid Emde
>>    WhereGroup GmbH & Co.KG
>>    Eifelstraße 7
>>    53119 Bonn
>>    Germany
>>    Fon: +49(0)228 90 90 38 - 22
>>    Fax: +49(0)228 90 90 38 - 11
>>    www.wheregroup.com
>>    Folgen Sie der WhereGroup auf twitter:
>> http://twitter.com/WhereGroup_com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Olaf Knopp, Peter Stamm
URL: <http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20190522/ce386779/attachment.html>
More information about the Mapbender_dev mailing list
