[Mapbender-dev] Mapbender 3.0.8 released 2019-04-12
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Thu May 23 22:39:01 PDT 2019
Am 2019-05-22 08:51, schrieb eric rasamoelina eric:
> hello , when I creat the element Mapklick ,I see the following error,
> ERROR - Uncaught PHP Exception
> Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "The
> application can not be found." at
> D:\ms4w\apps\mapbender3-starter-3.0.7.7\mapbender\src\Mapbender\CoreBundle\Controller\ApplicationController.php
> line 213
> can you help me!!
> Le sam. 27 avr. 2019 à 13:31, eric rasamoelina eric
> <eerriicc8181 at gmail.com> a écrit :
>> hello,please how to change the server logo and add the new function
>> same as statictics, login, ect,,
>> thank you
>> Le jeu. 18 avr. 2019 à 08:14, Astrid Emde (WhereGroup)
>> <astrid.emde at wheregroup.com> a écrit :
>>> Wow! Thanks a lot.
>>> Great news!
>>> Astrid
>>> Am 2019-04-17 20:17, schrieb Jeff McKenna:
>>>> Thanks for the great feedback Astrid!
>>>> The MS4W 4.0.0 installer now includes Mapbender 3.0.8
>>> https://ms4w.com
>>>> Thank you for using MS4W.
>>>> "MS4W: open doors as well as windows"
>>>> -jeff
>>>> Jeff McKenna
>>>> MapServer Consulting and Training Services
>>>> https://gatewaygeomatics.com/
>>>> On 2019-04-17 3:37 AM, Astrid Emde (WhereGroup) wrote:
>>>>> Hello Jeff,
>>>>> thanks for supporting the Mapbender project.
>>>>> Looking forward to have 3.0.8 on MS4W :)
>>>>> Feedback from our last Winterschool: Some participants wanted
>>> to use
>>>>> the stack on their windows machines (instead of OSGeoLive). It
>>> was so
>>>>> easy to setup Mapbender & MapServer with MS4W. Great! They were
>>>>> impressed. Thanks for providing MS4W!
>>>>> https://ms4w.com/
>>>>> Astrid
>>>>> Am 2019-04-15 14:55, schrieb Jeff McKenna:
>>>>>> Hi Rolf,
>>>>>> No problem I definitely understand. Thanks, will re-download.
>>>>>> -jeff
>>>>>> On 2019-04-15 9:50 AM, Rolf Neuberger wrote:
>>>>>>> Hi again Jeff,
>>>>>>> regarding the zip archives, we had some unfinshed packaging
>>> work on
>>>>>>> Friday, and going by the time stamps, it seems you caught an
>>> earlier
>>>>>>> version of the download where the build hadn't run properly.
>>>>>>> The updated zip package now available from
>>>>>>> https://mapbender.org/download does contain the
>>> bootstrap.php.cache
>>>>>>> file you're missing. Please download again.
>>>>>>> The package has been regenerated on Friday 15:42 German
>>> summer time.
>>>>>>> Sorry for the inconvenience.
>>>>>>> On 15.04.19 14:39, Jeff McKenna wrote:
>>>>>>>> Here is a history of that file being included in past
>>> release
>>>>>>>> archives:
>>>>>>>> - 3.0.8: missing
>>>>>>>> - 3.0.7.7 [1]: included in /app/bootstrap.php.cache
>>>>>>>> - 3.0.6.3 [2]: included in /app/bootstrap.php.cache
>>>>>>>> - 3.0.6.2 [3]: included in /app/bootstrap.php.cache
>>>>>>>> - 3.0.6.1 [4]: included in /app/bootstrap.php.cache
>>>>>>>> - 3.0.5.3 [5]: included in /app/bootstrap.php.cache
>>>>>>>> -jeff
>>>>>>>> On 2019-04-15 9:00 AM, Jeff McKenna wrote:
>>>>>>>>> For the record here is the new error with 3.0.8:
>>>>>>>>> Warning:
> require_once(C:\ms4w\apps\mapbender-starter-3.0.8\application\web/../app/bootstrap.php.cache):
>>>>>>>>> failed to open stream: No such file or directory in
>>> C:\ms4w\apps\mapbender-starter-3.0.8\application\web\app.php on
>>>>>>>>> line 6
>>>>>>>>> Fatal error: require_once(): Failed opening required
> 'C:\ms4w\apps\mapbender-starter-3.0.8\application\web/../app/bootstrap.php.cache'
>>>>>>>>> (include_path='.;\ms4w\Apache\php') in
>>>>>>>>> line 6
>>>>>>>>> -jeff
>>>>>>>>> On 2019-04-15 8:45 AM, Jeff McKenna wrote:
>>>>>>>>>> For example: mapbender3-starter-3.0.7.7.zip contained that
>>>>>>>>>> missing file (which I realize is not under version
>>> control, but
>>>>>>>>>> was packaged in previous releases).
>>>>>>>>>> I have never had to run that command in any previous
>>> release. I
>>>>>>>>>> also notice that that command is not part of the Mapbender
>>>>>>>>>> installation documentation.
>>>>>>>>>> So my point is, something has changed with that 3.0.8
>>> archive.
>>>>>>>>>> -jeff
>>>>>>>>>> On 2019-04-15 5:31 AM, Rolf Neuberger wrote:
>>>>>>>>>>> This is generated code. It's not under version control.
>>>>>>>>>>> The file is automatically generated by the bootstrap
>>> script in
>>>>>>>>>>> the project root, and implicitly also every time a
>>> compser
>>>>>>>>>>> package is installed or updated.
>>>>>>>>>>> You can explicitly trigger just the rebuild with a shell
>>>>>>>>>>> command:
>>>>>>>>>>> application$ bin/composer run build-bootstrap
>>>>>>>>>>> HTH,
>>>>>>>>>>> -Rolf
>>>>>>>>>>> On 12.04.19 14:38, Jeff McKenna wrote:
>>>>>>>>>>>> The release tags are missing a required file
>>>>>>>>>>>> -jeff
>>>> _______________________________________________
>>>> Mapbender_dev mailing list
>>>> Mapbender_dev at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
>>> Mit freundlichen Grüßen
>>> Astrid Emde
>>> GIS-Consultant
>>> Aufwind durch Wissen!
>>> Qualifizierte Open-Source-Schulungen
>>> bei der www.foss-academy.com [6]
>>> Astrid Emde
>>> WhereGroup GmbH & Co.KG
>>> Eifelstraße 7
>>> 53119 Bonn
>>> Germany
>>> Fon: +49(0)228 90 90 38 - 22
>>> Fax: +49(0)228 90 90 38 - 11
>>> www.wheregroup.com [7]
>>> Folgen Sie der WhereGroup auf twitter:
>>> http://twitter.com/WhereGroup_com
>>> Amtsgericht Bonn, HRA 6788
>>> Komplementärin:
>>> WhereGroup Verwaltungs GmbH
>>> vertreten durch:
>>> Olaf Knopp, Peter Stamm
> Links:
> [1] http://3.0.7.7
> [2] http://3.0.6.3
> [3] http://3.0.6.2
> [4] http://3.0.6.1
> [5] http://3.0.5.3
> [6] http://www.foss-academy.com
> [7] http://www.wheregroup.com
Hello Eric,
please note that the mapKlick example in the documentation is not
working at the moment.
You find an example of mapKlick element in the workshop bundle.
https://github.com/mapbender/mapbender-workshop/
Please note: for questions concerning mapbender functionality, please
use the mapbender-user mailing list.
You find it here:
http://lists.osgeo.org/mailman/listinfo/mapbender_users
Best regards
Astrid Emde
GIS-Consultant
Astrid Emde
Eifelstraße 7
53119 Bonn
Germany
www.wheregroup.com
Komplementärin:
vertreten durch:
More information about the Mapbender_dev
