[Mapbender-dev] Mapbender 3.2.0 released 2020-07-29
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Jul 31 06:31:46 PDT 2020
Thanks Astrid. Here is the new app, which you can extract over MS4W
4.0.4 : https://ms4w.com/release/apps/mapbender_3.2.0_ms4w.zip (I
haven't announced its availability yet, but I uploaded it there for you
to test)
-jeff
On 2020-07-31 10:02 a.m., Astrid Emde (WhereGroup) wrote:
> Hello Jeff,
> I will have a look to and give feedback in the ticket.
> Thanks for all your efforts
> Astrid
> Am 2020-07-31 14:39, schrieb Jeff McKenna:
>> Thanks Astrid, I'll be sure to use that starter link from now on.
>> This morning I've worked on trying to get this 3.2.0 package to work
>> on Windows, with the same settings as before (for FCGI + Apache) but
>> the demo map app hangs forever and causes fcgi errors in the Apache
>> error log as "mod_fcgid: get overlap result error" (see exact error
>> at https://ms4w.com/trac/ticket/277)
>> I'll keep working on this, but unfortunately I'm kind of stuck on
>> this. (I'm not sure what has changed in 3.2.0 that has caused new FCGI
>> errors)
>> I'll keep updating my progress through that ticket.
>> -jeff
>> Jeff McKenna
>> MapServer Consulting and Training Services
>> co-founder of FOSS4G
>> http://gatewaygeo.com/
>> On 2020-07-30 11:11 a.m., Astrid Emde (WhereGroup) wrote:
>>> Hello Jeff,
>>> the package is now available at
>>> https://mapbender.org/builds/3.2.0/mapbender-starter-v3.2.0.zip
>>> or as tar.gz
>>> You also could take the current package which always should refer to
>>> the actual version
>>> https://mapbender.org/builds/mapbender-starter-current.zip
>>> If you need any further help, let me know.
>>> Thanks a lot and greetings from Cologne
>>> Astrid
>>> Am 2020-07-30 13:07, schrieb Jeff McKenna:
>>>> Thanks Astrid, I didn't realize the difference, sorry about that.
>>>> Will watch for updates :)
>>>> -jeff
>>>> On 2020-07-30 6:16 a.m., Astrid Emde (WhereGroup) wrote:
>>>>> Hello Jeff,
>>>>> you normally use the build package from https://mapbender.org/builds/
>>>>> The package for Mapbender 3.2 is not there yet.
>>>>> When it is there the procedure will be as usual.
>>>>> we will inform you when the package is there.
>>>>> Thanks for integrating Mapbender in MS4W!!
>>>>> Greetings from Germany
>>>>> Astrid
>>>>> Am 2020-07-29 19:52, schrieb Jeff McKenna:
>>>>>> For the Windows community I've tried to update the MS4W package, but
>>>>>> the install docs and the new 3.2.0 structure differ (so
>>>>>> /mapbender/web/ no longer exists, but it is now
>>>>>> /mapbender/application/web/) etc. And after trying to adjust for the
>>>>>> new structure & loading /app.php/, I get errors of
>>>>>> application/app/autoload.php trying to include /vendor/autoload.php
>>>>>> (but there is no longer a 'vendor' folder in 3.2.0.
>>>>>> I am tracking this with the ticket: https://ms4w.com/trac/ticket/277
>>>>>> (if you want to jump in and help)
>>>>>> I will await the online docs
>>>>>> (https://doc.mapbender.org/en/installation.html) to be updated to
>>>>>> 3.2.0 and then will re-tackle this update, so 3.2.0 can then be
>>>>>> distributed to the Windows community. Or, you can follow along my
>>>>>> progress and join the fun, through the ticket.
>>>>>> thanks!
>>>>>> -jeff
>>>>>> -- Jeff McKenna
>>>>>> On 2020-07-29 12:35 p.m., Olaf Knopp (WhereGroup) wrote:
>>>>>>> See English version below
>>>>>>> ============= Deutsch ===============
>>>>>>> Hallo Mapbender-Community,
>>>>>>> das Mapbender-Entwicklungsteam hat am 29.07.2020 die neue
>>>>>>> Mapbender-Version 3.2.0 veröffentlicht. Herzlichen Dank an alle
>>>>>>> Beteiligten.
>>>>>>> Es handelt sich um die neue Mapbender-Version mit einigen
>>>>>>> technologischen und architektonischen Veränderungen. Sie folgt
>>>>>>> auf die LTS-Version 3.0.8.x, die noch bis zum 31.03.2021 mit
>>>>>>> Sicherheitsaktualisierungen versorgt wird.
>>>>>>> Wichtigste Änderungen sind der Einsatz von OpenLayers 6, das
>>>>>>> Update auf Symfony 3.4 LTS, die Implementierung von geteilten
>>>>>>> Dienste-Instanzen sowie diverse Aktualisierungen und
>>>>>>> Bugbehebungen. Außerdem wurde der Schwerpunkt weiterhin auf
>>>>>>> Stabilität und Performanz gelegt. Mit OpenLayers 6 kommen einige
>>>>>>> neue Features wie die Kartenrotation oder stufenloser Zoom. Mit
>>>>>>> den geteilten Diensteinstanzen können in Anwendungen
>>>>>>> konfigurierte Dienste in anderen Anwendungen verwendet und
>>>>>>> zentral konfiguriert werden. Mapbender 3.2.0 setzte mindestens
>>>>>>> PHP 7.1 voraus.
>>>>>>> Einige Funktionen wurden herausgenommen wie Meeting Point/POI und
>>>>>>> das WMC-Handling. Sie werden schnellstmöglich durch eine modernes
>>>>>>> "Share-Tool" ersetzt. Außerdem arbeiten wir am Refactoring des
>>>>>>> Digitizers.
>>>>>>> Alle Überarbeitungen im Detail können dem Change-Log entnommen
>>>>>>> werden:
>>>>>>> * https://github.com/mapbender/mapbender/releases
>>>>>>> Download 3.2.0:
>>>>>>> https://github.com/mapbender/mapbender-starter/archive/v3.2.0.tar.gz
>>>>>>> Tag v3.2.0 auf GitHub:
>>>>>>> https://github.com/mapbender/mapbender-starter/releases/tag/v3.2.0
>>>>>>> Helfen Sie mit Mapbender weiterzuentwickeln:
>>>>>>> * Developer Guide (Contributing.md):
>>>>>>> https://github.com/mapbender/mapbender-starter/blob/master/CONTRIBUTING.md
>>>>>>> Melden Sie Bugs
>>>>>>> * https://github.com/mapbender/mapbender/issues
>>>>>>> Die Dokumentation finden Sie hier:
>>>>>>> * https://doc.mapbender.org/de/
>>>>>>> Informationen zur Installation und Aktualisierung auf eine neue
>>>>>>> Version:
>>>>>>> * http://doc.mapbender.org/de/installation.html
>>>>>>> Probieren Sie Mapbender aus:
>>>>>>> * Mapbender-Tutorial, das die ersten Schritte mit Ihnen
>>>>>>> durchgeht:https://doc.mapbender.org/de/quickstart.html
>>>>>>> * Die neue Version: Mapbender-Demo https://demo.mapbender.org/
>>>>>>> Viel Spaß mit der neuen Version wünscht
>>>>>>> Das Mapbender Team
>>>>>>> ============ English =================
>>>>>>> Hello Mapbender community,
>>>>>>> the Mapbender development team has released the new Mapbender
>>>>>>> version 3.2.0 on July 29th, 2020. Thank you to everyone involved.
>>>>>>> It is the new Mapbender version with some technological and
>>>>>>> architectural changes. It follows the LTS version 3.0.8.x, for
>>>>>>> which we will provide security updates until March 31, 2021.
>>>>>>> The most important changes are the use of OpenLayers 6, the
>>>>>>> update to Symfony 3.4 LTS, the implementation of shared service
>>>>>>> instances as well as various updates and bug fixes. The focus was
>>>>>>> also on stability and performance. With OpenLayers 6 there are
>>>>>>> some new features such as map rotation or continuous zoom. With
>>>>>>> the shared service instances, services configured in applications
>>>>>>> can be used in other applications and configured centrally.
>>>>>>> Mapbender 3.2.0 requires at least PHP 7.1.
>>>>>>> Some functions have been removed, such as Meeting Point / POI and
>>>>>>> WMC handling. They will be replaced as soon as possible by a
>>>>>>> modern "share tool". We are also working on refactoring the
>>>>>>> digitizer.
>>>>>>> Please refer to changelog to find out about the changes:
>>>>>>> Download 3.2.0:
>>>>>>> Tag v3.2.0 at GitHub:
>>>>>>> If you would like to work and develop with the source code read
>>>>>>> the Developer Guide (Contributing.md)
>>>>>>> Report bugs:
>>>>>>> Documentation:
>>>>>>> * https://doc.mapbender.org/en/
>>>>>>> Installation and Update:
>>>>>>> * https://doc.mapbender.org/en/installation.html
>>>>>>> Try Mapbender or follow the Mapbender quickstart:
>>>>>>> * https://doc.mapbender.org/en/quickstart.html
>>>>>>> * Mapbender-demo: https://demo.mapbender.org/
>>>>>>> We wish you a lot of fun with the new version
>>>>>>> The Mapbender Team
>>>>>>> _______________________________________________
>>>>>>> Mapbender_dev mailing list
>>>>>>> Mapbender_dev at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
Jeff McKenna
More information about the Mapbender_dev
