[Mapbender-dev] Mapbender 3.2.0 released 2020-07-29
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Fri Jul 31 06:02:58 PDT 2020
Hello Jeff,
I will have a look to and give feedback in the ticket.
Thanks for all your efforts
Astrid
Am 2020-07-31 14:39, schrieb Jeff McKenna:
> Thanks Astrid, I'll be sure to use that starter link from now on.
> This morning I've worked on trying to get this 3.2.0 package to work
> on Windows, with the same settings as before (for FCGI + Apache) but
> the demo map app hangs forever and causes fcgi errors in the Apache
> error log as "mod_fcgid: get overlap result error"  (see exact error
> at https://ms4w.com/trac/ticket/277)
> I'll keep working on this, but unfortunately I'm kind of stuck on
> this. (I'm not sure what has changed in 3.2.0 that has caused new FCGI
> errors)
> I'll keep updating my progress through that ticket.
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> co-founder of FOSS4G
> http://gatewaygeo.com/
> On 2020-07-30 11:11 a.m., Astrid Emde (WhereGroup) wrote:
>> Hello Jeff,
>> the package is now available at
>> https://mapbender.org/builds/3.2.0/mapbender-starter-v3.2.0.zip
>> or as tar.gz
>> You also could take the current package which always should refer to
>> the actual version
>> https://mapbender.org/builds/mapbender-starter-current.zip
>> If you need any further help, let me know.
>> Thanks a lot and greetings from Cologne
>> Astrid
>> Am 2020-07-30 13:07, schrieb Jeff McKenna:
>>> Thanks Astrid, I didn't realize the difference, sorry about that.
>>> Will watch for updates :)
>>> -jeff
>>> On 2020-07-30 6:16 a.m., Astrid Emde (WhereGroup) wrote:
>>>> Hello Jeff,
>>>> you normally use the build package from
>>>> The package for Mapbender 3.2 is not there yet.
>>>> When it is there the procedure will be as usual.
>>>> we will inform you when the package is there.
>>>> Thanks for integrating Mapbender in MS4W!!
>>>> Greetings from Germany
>>>> Astrid
>>>> Am 2020-07-29 19:52, schrieb Jeff McKenna:
>>>>> For the Windows community I've tried to update the MS4W package,
>>>>> but
>>>>> the install docs and the new 3.2.0 structure differ (so
>>>>> /mapbender/web/ no longer exists, but it is now
>>>>> /mapbender/application/web/) etc.  And after trying to adjust for
>>>>> the
>>>>> new structure & loading /app.php/, I get errors of
>>>>> application/app/autoload.php trying to include /vendor/autoload.php
>>>>> (but there is no longer a 'vendor' folder in 3.2.0.
>>>>> I am tracking this with the ticket:
>>>>> (if you want to jump in and help)
>>>>> I will await the online docs
>>>>> (https://doc.mapbender.org/en/installation.html) to be updated to
>>>>> 3.2.0 and then will re-tackle this update, so 3.2.0 can then be
>>>>> distributed to the Windows community.   Or, you can follow along my
>>>>> progress and join the fun, through the ticket.
>>>>> thanks!
>>>>> -jeff
>>>>> -- Jeff McKenna
>>>>> On 2020-07-29 12:35 p.m., Olaf Knopp (WhereGroup) wrote:
>>>>>> See English version below
>>>>>> ============= Deutsch ===============
>>>>>> Hallo Mapbender-Community,
>>>>>> das Mapbender-Entwicklungsteam hat am 29.07.2020 die neue
>>>>>> Mapbender-Version 3.2.0 veröffentlicht. Herzlichen Dank an alle
>>>>>> Beteiligten.
>>>>>> Es handelt sich um die neue Mapbender-Version mit einigen
>>>>>> technologischen und architektonischen Veränderungen. Sie folgt auf
>>>>>> die LTS-Version 3.0.8.x, die noch bis zum 31.03.2021 mit
>>>>>> Sicherheitsaktualisierungen versorgt wird.
>>>>>> Wichtigste Änderungen sind der Einsatz von OpenLayers 6, das
>>>>>> Update auf Symfony 3.4 LTS, die Implementierung von geteilten
>>>>>> Dienste-Instanzen sowie diverse Aktualisierungen und
>>>>>> Bugbehebungen. Außerdem wurde der Schwerpunkt weiterhin auf
>>>>>> Stabilität und Performanz gelegt. Mit OpenLayers 6 kommen einige
>>>>>> neue Features wie die Kartenrotation oder stufenloser Zoom. Mit
>>>>>> den geteilten Diensteinstanzen können in Anwendungen konfigurierte
>>>>>> Dienste in anderen Anwendungen verwendet und zentral konfiguriert
>>>>>> werden. Mapbender 3.2.0 setzte mindestens PHP 7.1 voraus.
>>>>>> Einige Funktionen wurden herausgenommen wie Meeting Point/POI und
>>>>>> das WMC-Handling. Sie werden schnellstmöglich durch eine modernes
>>>>>> "Share-Tool" ersetzt. Außerdem arbeiten wir am Refactoring des
>>>>>> Digitizers.
>>>>>> Alle Überarbeitungen im Detail können dem Change-Log entnommen
>>>>>> werden:
>>>>>>   * https://github.com/mapbender/mapbender/releases
>>>>>> Download 3.2.0:
>>>>>> https://github.com/mapbender/mapbender-starter/archive/v3.2.0.tar.gz
>>>>>> Tag v3.2.0 auf GitHub:
>>>>>> https://github.com/mapbender/mapbender-starter/releases/tag/v3.2.0
>>>>>> Helfen Sie mit Mapbender weiterzuentwickeln:
>>>>>>   * Developer Guide (Contributing.md):
>>>>>> https://github.com/mapbender/mapbender-starter/blob/master/CONTRIBUTING.md
>>>>>> Melden Sie Bugs
>>>>>>   * https://github.com/mapbender/mapbender/issues
>>>>>> Die Dokumentation finden Sie hier:
>>>>>>   * https://doc.mapbender.org/de/
>>>>>> Informationen zur Installation und Aktualisierung auf eine neue
>>>>>> Version:
>>>>>>   * http://doc.mapbender.org/de/installation.html
>>>>>> Probieren Sie Mapbender aus:
>>>>>>   * Mapbender-Tutorial, das die ersten Schritte mit Ihnen
>>>>>>     durchgeht:https://doc.mapbender.org/de/quickstart.html
>>>>>>   * Die neue Version: Mapbender-Demo https://demo.mapbender.org/
>>>>>> Viel Spaß mit der neuen Version wünscht
>>>>>> Das Mapbender Team
>>>>>> ============ English =================
>>>>>> Hello Mapbender community,
>>>>>> the Mapbender development team has released the new Mapbender
>>>>>> version 3.2.0 on July 29th, 2020. Thank you to everyone involved.
>>>>>> It is the new Mapbender version with some technological and
>>>>>> architectural changes. It follows the LTS version 3.0.8.x, for
>>>>>> which we will provide security updates until March 31, 2021.
>>>>>> The most important changes are the use of OpenLayers 6, the update
>>>>>> to Symfony 3.4 LTS, the implementation of shared service instances
>>>>>> as well as various updates and bug fixes. The focus was also on
>>>>>> stability and performance. With OpenLayers 6 there are some new
>>>>>> features such as map rotation or continuous zoom. With the shared
>>>>>> service instances, services configured in applications can be used
>>>>>> in other applications and configured centrally. Mapbender 3.2.0
>>>>>> requires at least PHP 7.1.
>>>>>> Some functions have been removed, such as Meeting Point / POI and
>>>>>> WMC handling. They will be replaced as soon as possible by a
>>>>>> modern "share tool". We are also working on refactoring the
>>>>>> digitizer.
>>>>>> Please refer to changelog to find out about the changes:
>>>>>> Download 3.2.0:
>>>>>> Tag v3.2.0 at GitHub:
>>>>>> If you would like to work and develop with the source code read
>>>>>> the Developer Guide (Contributing.md)
>>>>>> Report bugs:
>>>>>> Documentation:
>>>>>>   * https://doc.mapbender.org/en/
>>>>>> Installation and Update:
>>>>>>   * https://doc.mapbender.org/en/installation.html
>>>>>> Try Mapbender or follow the Mapbender quickstart:
>>>>>>   * https://doc.mapbender.org/en/quickstart.html
>>>>>>   * Mapbender-demo: https://demo.mapbender.org/
>>>>>> We wish you a lot of fun with the new version
>>>>>> The Mapbender Team
>>>>>> _______________________________________________
>>>>>> Mapbender_dev mailing list
>>>>>> Mapbender_dev at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
  Aufwind durch Wissen!
  Jetzt neu: Web-Seminare und Online-Schulungen
  bei der www.foss-academy.com
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Fon: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_dev mailing list
