[Mapbender-dev] Mapbender 3.2.0 released 2020-07-29
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Jul 31 05:39:52 PDT 2020
Thanks Astrid, I'll be sure to use that starter link from now on.
This morning I've worked on trying to get this 3.2.0 package to work on
Windows, with the same settings as before (for FCGI + Apache) but the
demo map app hangs forever and causes fcgi errors in the Apache error
log as "mod_fcgid: get overlap result error" (see exact error at
https://ms4w.com/trac/ticket/277)
I'll keep working on this, but unfortunately I'm kind of stuck on this.
(I'm not sure what has changed in 3.2.0 that has caused new FCGI errors)
I'll keep updating my progress through that ticket.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
On 2020-07-30 11:11 a.m., Astrid Emde (WhereGroup) wrote:
> Hello Jeff,
> the package is now available at
> https://mapbender.org/builds/3.2.0/mapbender-starter-v3.2.0.zip
> or as tar.gz
> You also could take the current package which always should refer to the
> actual version
> https://mapbender.org/builds/mapbender-starter-current.zip
> If you need any further help, let me know.
> Thanks a lot and greetings from Cologne
> Astrid
> Am 2020-07-30 13:07, schrieb Jeff McKenna:
>> Thanks Astrid, I didn't realize the difference, sorry about that.
>> Will watch for updates :)
>> -jeff
>> On 2020-07-30 6:16 a.m., Astrid Emde (WhereGroup) wrote:
>>> Hello Jeff,
>>> you normally use the build package from https://mapbender.org/builds/
>>> The package for Mapbender 3.2 is not there yet.
>>> When it is there the procedure will be as usual.
>>> we will inform you when the package is there.
>>> Thanks for integrating Mapbender in MS4W!!
>>> Greetings from Germany
>>> Astrid
>>> Am 2020-07-29 19:52, schrieb Jeff McKenna:
>>>> For the Windows community I've tried to update the MS4W package, but
>>>> the install docs and the new 3.2.0 structure differ (so
>>>> /mapbender/web/ no longer exists, but it is now
>>>> /mapbender/application/web/) etc. And after trying to adjust for the
>>>> new structure & loading /app.php/, I get errors of
>>>> application/app/autoload.php trying to include /vendor/autoload.php
>>>> (but there is no longer a 'vendor' folder in 3.2.0.
>>>> I am tracking this with the ticket: https://ms4w.com/trac/ticket/277
>>>> (if you want to jump in and help)
>>>> I will await the online docs
>>>> (https://doc.mapbender.org/en/installation.html) to be updated to
>>>> 3.2.0 and then will re-tackle this update, so 3.2.0 can then be
>>>> distributed to the Windows community. Or, you can follow along my
>>>> progress and join the fun, through the ticket.
>>>> thanks!
>>>> -jeff
>>>> -- Jeff McKenna
>>>> On 2020-07-29 12:35 p.m., Olaf Knopp (WhereGroup) wrote:
>>>>> See English version below
>>>>> ============= Deutsch ===============
>>>>> Hallo Mapbender-Community,
>>>>> das Mapbender-Entwicklungsteam hat am 29.07.2020 die neue
>>>>> Mapbender-Version 3.2.0 veröffentlicht. Herzlichen Dank an alle
>>>>> Beteiligten.
>>>>> Es handelt sich um die neue Mapbender-Version mit einigen
>>>>> technologischen und architektonischen Veränderungen. Sie folgt auf
>>>>> die LTS-Version 3.0.8.x, die noch bis zum 31.03.2021 mit
>>>>> Sicherheitsaktualisierungen versorgt wird.
>>>>> Wichtigste Änderungen sind der Einsatz von OpenLayers 6, das Update
>>>>> auf Symfony 3.4 LTS, die Implementierung von geteilten
>>>>> Dienste-Instanzen sowie diverse Aktualisierungen und Bugbehebungen.
>>>>> Außerdem wurde der Schwerpunkt weiterhin auf Stabilität und
>>>>> Performanz gelegt. Mit OpenLayers 6 kommen einige neue Features wie
>>>>> die Kartenrotation oder stufenloser Zoom. Mit den geteilten
>>>>> Diensteinstanzen können in Anwendungen konfigurierte Dienste in
>>>>> anderen Anwendungen verwendet und zentral konfiguriert werden.
>>>>> Mapbender 3.2.0 setzte mindestens PHP 7.1 voraus.
>>>>> Einige Funktionen wurden herausgenommen wie Meeting Point/POI und
>>>>> das WMC-Handling. Sie werden schnellstmöglich durch eine modernes
>>>>> "Share-Tool" ersetzt. Außerdem arbeiten wir am Refactoring des
>>>>> Digitizers.
>>>>> Alle Überarbeitungen im Detail können dem Change-Log entnommen werden:
>>>>> * https://github.com/mapbender/mapbender/releases
>>>>> Download 3.2.0:
>>>>> https://github.com/mapbender/mapbender-starter/archive/v3.2.0.tar.gz
>>>>> Tag v3.2.0 auf GitHub:
>>>>> * https://github.com/mapbender/mapbender-starter/releases/tag/v3.2.0
>>>>> Helfen Sie mit Mapbender weiterzuentwickeln:
>>>>> * Developer Guide (Contributing.md):
>>>>> https://github.com/mapbender/mapbender-starter/blob/master/CONTRIBUTING.md
>>>>> Melden Sie Bugs
>>>>> * https://github.com/mapbender/mapbender/issues
>>>>> Die Dokumentation finden Sie hier:
>>>>> * https://doc.mapbender.org/de/
>>>>> Informationen zur Installation und Aktualisierung auf eine neue
>>>>> Version:
>>>>> * http://doc.mapbender.org/de/installation.html
>>>>> Probieren Sie Mapbender aus:
>>>>> * Mapbender-Tutorial, das die ersten Schritte mit Ihnen
>>>>> durchgeht:https://doc.mapbender.org/de/quickstart.html
>>>>> * Die neue Version: Mapbender-Demo https://demo.mapbender.org/
>>>>> Viel Spaß mit der neuen Version wünscht
>>>>> Das Mapbender Team
>>>>> ============ English =================
>>>>> Hello Mapbender community,
>>>>> the Mapbender development team has released the new Mapbender
>>>>> version 3.2.0 on July 29th, 2020. Thank you to everyone involved.
>>>>> It is the new Mapbender version with some technological and
>>>>> architectural changes. It follows the LTS version 3.0.8.x, for
>>>>> which we will provide security updates until March 31, 2021.
>>>>> The most important changes are the use of OpenLayers 6, the update
>>>>> to Symfony 3.4 LTS, the implementation of shared service instances
>>>>> as well as various updates and bug fixes. The focus was also on
>>>>> stability and performance. With OpenLayers 6 there are some new
>>>>> features such as map rotation or continuous zoom. With the shared
>>>>> service instances, services configured in applications can be used
>>>>> in other applications and configured centrally. Mapbender 3.2.0
>>>>> requires at least PHP 7.1.
>>>>> Some functions have been removed, such as Meeting Point / POI and
>>>>> WMC handling. They will be replaced as soon as possible by a modern
>>>>> "share tool". We are also working on refactoring the digitizer.
>>>>> Please refer to changelog to find out about the changes:
>>>>> Download 3.2.0:
>>>>> Tag v3.2.0 at GitHub:
>>>>> If you would like to work and develop with the source code read the
>>>>> Report bugs:
>>>>> Documentation:
>>>>> * https://doc.mapbender.org/en/
>>>>> Installation and Update:
>>>>> * https://doc.mapbender.org/en/installation.html
>>>>> Try Mapbender or follow the Mapbender quickstart:
>>>>> * https://doc.mapbender.org/en/quickstart.html
>>>>> * Mapbender-demo: https://demo.mapbender.org/
>>>>> We wish you a lot of fun with the new version
>>>>> The Mapbender Team
>>>>> _______________________________________________
>>>>> Mapbender_dev mailing list
>>>>> Mapbender_dev at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev
