[Mapbender-dev] Mapbender 3.2.0 released 2020-07-29
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Thu Jul 30 07:11:34 PDT 2020
Hello Jeff,
the package is now available at
https://mapbender.org/builds/3.2.0/mapbender-starter-v3.2.0.zip
or as tar.gz
You also could take the current package which always should refer to the
actual version
https://mapbender.org/builds/mapbender-starter-current.zip
If you need any further help, let me know.
Thanks a lot and greetings from Cologne
Astrid
Am 2020-07-30 13:07, schrieb Jeff McKenna:
> Thanks Astrid, I didn't realize the difference, sorry about that.
> Will watch for updates :)
> -jeff
> On 2020-07-30 6:16 a.m., Astrid Emde (WhereGroup) wrote:
>> Hello Jeff,
>> you normally use the build package from https://mapbender.org/builds/
>> The package for Mapbender 3.2 is not there yet.
>> When it is there the procedure will be as usual.
>> we will inform you when the package is there.
>> Thanks for integrating Mapbender in MS4W!!
>> Greetings from Germany
>> Astrid
>> Am 2020-07-29 19:52, schrieb Jeff McKenna:
>>> For the Windows community I've tried to update the MS4W package, but
>>> the install docs and the new 3.2.0 structure differ (so
>>> /mapbender/web/ no longer exists, but it is now
>>> /mapbender/application/web/) etc. And after trying to adjust for the
>>> new structure & loading /app.php/, I get errors of
>>> application/app/autoload.php trying to include /vendor/autoload.php
>>> (but there is no longer a 'vendor' folder in 3.2.0.
>>> I am tracking this with the ticket: https://ms4w.com/trac/ticket/277
>>> (if you want to jump in and help)
>>> I will await the online docs
>>> (https://doc.mapbender.org/en/installation.html) to be updated to
>>> 3.2.0 and then will re-tackle this update, so 3.2.0 can then be
>>> distributed to the Windows community. Or, you can follow along my
>>> progress and join the fun, through the ticket.
>>> thanks!
>>> -jeff
>>> -- Jeff McKenna
>>> MapServer Consulting and Training Services
>>> co-founder of FOSS4G
>>> http://gatewaygeo.com/
>>> On 2020-07-29 12:35 p.m., Olaf Knopp (WhereGroup) wrote:
>>>> See English version below
>>>> ============= Deutsch ===============
>>>> Hallo Mapbender-Community,
>>>> das Mapbender-Entwicklungsteam hat am 29.07.2020 die neue
>>>> Mapbender-Version 3.2.0 veröffentlicht. Herzlichen Dank an alle
>>>> Beteiligten.
>>>> Es handelt sich um die neue Mapbender-Version mit einigen
>>>> technologischen und architektonischen Veränderungen. Sie folgt auf
>>>> die LTS-Version 3.0.8.x, die noch bis zum 31.03.2021 mit
>>>> Sicherheitsaktualisierungen versorgt wird.
>>>> Wichtigste Änderungen sind der Einsatz von OpenLayers 6, das Update
>>>> auf Symfony 3.4 LTS, die Implementierung von geteilten
>>>> Dienste-Instanzen sowie diverse Aktualisierungen und Bugbehebungen.
>>>> Außerdem wurde der Schwerpunkt weiterhin auf Stabilität und
>>>> Performanz gelegt. Mit OpenLayers 6 kommen einige neue Features wie
>>>> die Kartenrotation oder stufenloser Zoom. Mit den geteilten
>>>> Diensteinstanzen können in Anwendungen konfigurierte Dienste in
>>>> anderen Anwendungen verwendet und zentral konfiguriert werden.
>>>> Mapbender 3.2.0 setzte mindestens PHP 7.1 voraus.
>>>> Einige Funktionen wurden herausgenommen wie Meeting Point/POI und
>>>> das WMC-Handling. Sie werden schnellstmöglich durch eine modernes
>>>> "Share-Tool" ersetzt. Außerdem arbeiten wir am Refactoring des
>>>> Digitizers.
>>>> Alle Überarbeitungen im Detail können dem Change-Log entnommen
>>>> werden:
>>>> * https://github.com/mapbender/mapbender/releases
>>>> Download 3.2.0:
>>>> https://github.com/mapbender/mapbender-starter/archive/v3.2.0.tar.gz
>>>> Tag v3.2.0 auf GitHub:
>>>> https://github.com/mapbender/mapbender-starter/releases/tag/v3.2.0
>>>> Helfen Sie mit Mapbender weiterzuentwickeln:
>>>> * Developer Guide (Contributing.md):
>>>> https://github.com/mapbender/mapbender-starter/blob/master/CONTRIBUTING.md
>>>> Melden Sie Bugs
>>>> * https://github.com/mapbender/mapbender/issues
>>>> Die Dokumentation finden Sie hier:
>>>> * https://doc.mapbender.org/de/
>>>> Informationen zur Installation und Aktualisierung auf eine neue
>>>> Version:
>>>> * http://doc.mapbender.org/de/installation.html
>>>> Probieren Sie Mapbender aus:
>>>> * Mapbender-Tutorial, das die ersten Schritte mit Ihnen
>>>> durchgeht:https://doc.mapbender.org/de/quickstart.html
>>>> * Die neue Version: Mapbender-Demo https://demo.mapbender.org/
>>>> Viel Spaß mit der neuen Version wünscht
>>>> Das Mapbender Team
>>>> ============ English =================
>>>> Hello Mapbender community,
>>>> the Mapbender development team has released the new Mapbender
>>>> version 3.2.0 on July 29th, 2020. Thank you to everyone involved.
>>>> It is the new Mapbender version with some technological and
>>>> architectural changes. It follows the LTS version 3.0.8.x, for which
>>>> we will provide security updates until March 31, 2021.
>>>> The most important changes are the use of OpenLayers 6, the update
>>>> to Symfony 3.4 LTS, the implementation of shared service instances
>>>> as well as various updates and bug fixes. The focus was also on
>>>> stability and performance. With OpenLayers 6 there are some new
>>>> features such as map rotation or continuous zoom. With the shared
>>>> service instances, services configured in applications can be used
>>>> in other applications and configured centrally. Mapbender 3.2.0
>>>> requires at least PHP 7.1.
>>>> Some functions have been removed, such as Meeting Point / POI and
>>>> WMC handling. They will be replaced as soon as possible by a modern
>>>> "share tool". We are also working on refactoring the digitizer.
>>>> Please refer to changelog to find out about the changes:
>>>> Download 3.2.0:
>>>> Tag v3.2.0 at GitHub:
>>>> If you would like to work and develop with the source code read the
>>>> Report bugs:
>>>> Documentation:
>>>> * https://doc.mapbender.org/en/
>>>> Installation and Update:
>>>> * https://doc.mapbender.org/en/installation.html
>>>> Try Mapbender or follow the Mapbender quickstart:
>>>> * https://doc.mapbender.org/en/quickstart.html
>>>> * Mapbender-demo: https://demo.mapbender.org/
>>>> We wish you a lot of fun with the new version
>>>> The Mapbender Team
>>>> _______________________________________________
>>>> Mapbender_dev mailing list
>>>> Mapbender_dev at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Jetzt neu: Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_dev
