[Mapbender-dev] Mapbender 3.2.0 released 2020-07-29
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Jul 30 04:07:45 PDT 2020
Thanks Astrid, I didn't realize the difference, sorry about that. Will
watch for updates :)
-jeff
On 2020-07-30 6:16 a.m., Astrid Emde (WhereGroup) wrote:
> Hello Jeff,
> you normally use the build package from https://mapbender.org/builds/
> The package for Mapbender 3.2 is not there yet.
> When it is there the procedure will be as usual.
> we will inform you when the package is there.
> Thanks for integrating Mapbender in MS4W!!
> Greetings from Germany
> Astrid
> Am 2020-07-29 19:52, schrieb Jeff McKenna:
>> For the Windows community I've tried to update the MS4W package, but
>> the install docs and the new 3.2.0 structure differ (so
>> /mapbender/web/ no longer exists, but it is now
>> /mapbender/application/web/) etc. And after trying to adjust for the
>> new structure & loading /app.php/, I get errors of
>> application/app/autoload.php trying to include /vendor/autoload.php
>> (but there is no longer a 'vendor' folder in 3.2.0.
>> I am tracking this with the ticket: https://ms4w.com/trac/ticket/277
>> (if you want to jump in and help)
>> I will await the online docs
>> (https://doc.mapbender.org/en/installation.html) to be updated to
>> 3.2.0 and then will re-tackle this update, so 3.2.0 can then be
>> distributed to the Windows community. Or, you can follow along my
>> progress and join the fun, through the ticket.
>> thanks!
>> -jeff
>> Jeff McKenna
>> MapServer Consulting and Training Services
>> co-founder of FOSS4G
>> http://gatewaygeo.com/
>> On 2020-07-29 12:35 p.m., Olaf Knopp (WhereGroup) wrote:
>>> See English version below
>>> ============= Deutsch ===============
>>> Hallo Mapbender-Community,
>>> das Mapbender-Entwicklungsteam hat am 29.07.2020 die neue
>>> Mapbender-Version 3.2.0 veröffentlicht. Herzlichen Dank an alle
>>> Beteiligten.
>>> Es handelt sich um die neue Mapbender-Version mit einigen
>>> technologischen und architektonischen Veränderungen. Sie folgt auf
>>> die LTS-Version 3.0.8.x, die noch bis zum 31.03.2021 mit
>>> Sicherheitsaktualisierungen versorgt wird.
>>> Wichtigste Änderungen sind der Einsatz von OpenLayers 6, das Update
>>> auf Symfony 3.4 LTS, die Implementierung von geteilten
>>> Dienste-Instanzen sowie diverse Aktualisierungen und Bugbehebungen.
>>> Außerdem wurde der Schwerpunkt weiterhin auf Stabilität und
>>> Performanz gelegt. Mit OpenLayers 6 kommen einige neue Features wie
>>> die Kartenrotation oder stufenloser Zoom. Mit den geteilten
>>> Diensteinstanzen können in Anwendungen konfigurierte Dienste in
>>> anderen Anwendungen verwendet und zentral konfiguriert werden.
>>> Mapbender 3.2.0 setzte mindestens PHP 7.1 voraus.
>>> Einige Funktionen wurden herausgenommen wie Meeting Point/POI und das
>>> WMC-Handling. Sie werden schnellstmöglich durch eine modernes
>>> "Share-Tool" ersetzt. Außerdem arbeiten wir am Refactoring des
>>> Digitizers.
>>> Alle Überarbeitungen im Detail können dem Change-Log entnommen werden:
>>> * https://github.com/mapbender/mapbender/releases
>>> Download 3.2.0:
>>> * https://github.com/mapbender/mapbender-starter/archive/v3.2.0.tar.gz
>>> Tag v3.2.0 auf GitHub:
>>> * https://github.com/mapbender/mapbender-starter/releases/tag/v3.2.0
>>> Helfen Sie mit Mapbender weiterzuentwickeln:
>>> * Developer Guide (Contributing.md):
>>> https://github.com/mapbender/mapbender-starter/blob/master/CONTRIBUTING.md
>>> Melden Sie Bugs
>>> * https://github.com/mapbender/mapbender/issues
>>> Die Dokumentation finden Sie hier:
>>> * https://doc.mapbender.org/de/
>>> Informationen zur Installation und Aktualisierung auf eine neue Version:
>>> * http://doc.mapbender.org/de/installation.html
>>> Probieren Sie Mapbender aus:
>>> * Mapbender-Tutorial, das die ersten Schritte mit Ihnen
>>> durchgeht:https://doc.mapbender.org/de/quickstart.html
>>> * Die neue Version: Mapbender-Demo https://demo.mapbender.org/
>>> Viel Spaß mit der neuen Version wünscht
>>> Das Mapbender Team
>>> ============ English =================
>>> Hello Mapbender community,
>>> the Mapbender development team has released the new Mapbender version
>>> 3.2.0 on July 29th, 2020. Thank you to everyone involved.
>>> It is the new Mapbender version with some technological and
>>> architectural changes. It follows the LTS version 3.0.8.x, for which
>>> we will provide security updates until March 31, 2021.
>>> The most important changes are the use of OpenLayers 6, the update to
>>> Symfony 3.4 LTS, the implementation of shared service instances as
>>> well as various updates and bug fixes. The focus was also on
>>> stability and performance. With OpenLayers 6 there are some new
>>> features such as map rotation or continuous zoom. With the shared
>>> service instances, services configured in applications can be used in
>>> other applications and configured centrally. Mapbender 3.2.0 requires
>>> at least PHP 7.1.
>>> Some functions have been removed, such as Meeting Point / POI and WMC
>>> handling. They will be replaced as soon as possible by a modern
>>> "share tool". We are also working on refactoring the digitizer.
>>> Please refer to changelog to find out about the changes:
>>> Download 3.2.0:
>>> Tag v3.2.0 at GitHub:
>>> If you would like to work and develop with the source code read the
>>> Report bugs:
>>> Documentation:
>>> * https://doc.mapbender.org/en/
>>> Installation and Update:
>>> * https://doc.mapbender.org/en/installation.html
>>> Try Mapbender or follow the Mapbender quickstart:
>>> * https://doc.mapbender.org/en/quickstart.html
>>> * Mapbender-demo: https://demo.mapbender.org/
>>> We wish you a lot of fun with the new version
>>> The Mapbender Team
>>> Mapbender_dev mailing list
>>> Mapbender_dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
Jeff McKenna
More information about the Mapbender_dev
