[Mapbender-dev] Mapbender 3.2.0 released 2020-07-29
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Thu Jul 30 02:16:09 PDT 2020
Hello Jeff,
you normally use the build package from https://mapbender.org/builds/
The package for Mapbender 3.2 is not there yet.
When it is there the procedure will be as usual.
we will inform you when the package is there.
Thanks for integrating Mapbender in MS4W!!
Greetings from Germany
Astrid
Am 2020-07-29 19:52, schrieb Jeff McKenna:
> For the Windows community I've tried to update the MS4W package, but
> the install docs and the new 3.2.0 structure differ (so
> /mapbender/web/ no longer exists, but it is now
> /mapbender/application/web/) etc.  And after trying to adjust for the
> new structure & loading /app.php/, I get errors of
> application/app/autoload.php trying to include /vendor/autoload.php
> (but there is no longer a 'vendor' folder in 3.2.0.
> I am tracking this with the ticket: https://ms4w.com/trac/ticket/277
> (if you want to jump in and help)
> I will await the online docs
> (https://doc.mapbender.org/en/installation.html) to be updated to
> 3.2.0 and then will re-tackle this update, so 3.2.0 can then be
> distributed to the Windows community.   Or, you can follow along my
> progress and join the fun, through the ticket.
> thanks!
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> co-founder of FOSS4G
> http://gatewaygeo.com/
> On 2020-07-29 12:35 p.m., Olaf Knopp (WhereGroup) wrote:
>> See English version below
>> ============= Deutsch ===============
>> Hallo Mapbender-Community,
>> das Mapbender-Entwicklungsteam hat am 29.07.2020 die neue
>> Mapbender-Version 3.2.0 veröffentlicht. Herzlichen Dank an alle
>> Beteiligten.
>> Es handelt sich um die neue Mapbender-Version mit einigen
>> technologischen und architektonischen Veränderungen. Sie folgt auf die
>> LTS-Version 3.0.8.x, die noch bis zum 31.03.2021 mit
>> Sicherheitsaktualisierungen versorgt wird.
>> Wichtigste Änderungen sind der Einsatz von OpenLayers 6, das Update
>> auf Symfony 3.4 LTS, die Implementierung von geteilten
>> Dienste-Instanzen sowie diverse Aktualisierungen und Bugbehebungen.
>> Außerdem wurde der Schwerpunkt weiterhin auf Stabilität und Performanz
>> gelegt. Mit OpenLayers 6 kommen einige neue Features wie die
>> Kartenrotation oder stufenloser Zoom. Mit den geteilten
>> Diensteinstanzen können in Anwendungen konfigurierte Dienste in
>> anderen Anwendungen verwendet und zentral konfiguriert werden.
>> Mapbender 3.2.0 setzte mindestens PHP 7.1 voraus.
>> Einige Funktionen wurden herausgenommen wie Meeting Point/POI und das
>> WMC-Handling. Sie werden schnellstmöglich durch eine modernes
>> "Share-Tool" ersetzt. Außerdem arbeiten wir am Refactoring des
>> Digitizers.
>> Alle Überarbeitungen im Detail können dem Change-Log entnommen werden:
>>   * https://github.com/mapbender/mapbender/releases
>> Download 3.2.0:
>> https://github.com/mapbender/mapbender-starter/archive/v3.2.0.tar.gz
>> Tag v3.2.0 auf GitHub:
>>   * https://github.com/mapbender/mapbender-starter/releases/tag/v3.2.0
>> Helfen Sie mit Mapbender weiterzuentwickeln:
>>   * Developer Guide (Contributing.md):
>> https://github.com/mapbender/mapbender-starter/blob/master/CONTRIBUTING.md
>> Melden Sie Bugs
>>   * https://github.com/mapbender/mapbender/issues
>> Die Dokumentation finden Sie hier:
>>   * https://doc.mapbender.org/de/
>> Informationen zur Installation und Aktualisierung auf eine neue
>> Version:
>>   * http://doc.mapbender.org/de/installation.html
>> Probieren Sie Mapbender aus:
>>   * Mapbender-Tutorial, das die ersten Schritte mit Ihnen
>>     durchgeht:https://doc.mapbender.org/de/quickstart.html
>>   * Die neue Version: Mapbender-Demo https://demo.mapbender.org/
>> Viel Spaß mit der neuen Version wünscht
>> Das Mapbender Team
>> ============ English =================
>> Hello Mapbender community,
>> the Mapbender development team has released the new Mapbender version
>> 3.2.0 on July 29th, 2020. Thank you to everyone involved.
>> It is the new Mapbender version with some technological and
>> architectural changes. It follows the LTS version 3.0.8.x, for which
>> we will provide security updates until March 31, 2021.
>> The most important changes are the use of OpenLayers 6, the update to
>> Symfony 3.4 LTS, the implementation of shared service instances as
>> well as various updates and bug fixes. The focus was also on stability
>> and performance. With OpenLayers 6 there are some new features such as
>> map rotation or continuous zoom. With the shared service instances,
>> services configured in applications can be used in other applications
>> and configured centrally. Mapbender 3.2.0 requires at least PHP 7.1.
>> Some functions have been removed, such as Meeting Point / POI and WMC
>> handling. They will be replaced as soon as possible by a modern "share
>> tool". We are also working on refactoring the digitizer.
>> Please refer to changelog to find out about the changes:
>> Download 3.2.0:
>> Tag v3.2.0 at GitHub:
>> If you would like to work and develop with the source code read the
>> Report bugs:
>> Documentation:
>>   * https://doc.mapbender.org/en/
>> Installation and Update:
>>   * https://doc.mapbender.org/en/installation.html
>> Try Mapbender or follow the Mapbender quickstart:
>>   * https://doc.mapbender.org/en/quickstart.html
>>   * Mapbender-demo: https://demo.mapbender.org/
>> We wish you a lot of fun with the new version
>> The Mapbender Team
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
  Aufwind durch Wissen!
  Jetzt neu: Web-Seminare und Online-Schulungen
  bei der www.foss-academy.com
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Fon: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_dev mailing list
