AW: [Mapbender-users] document.getElementById(tab_ids[i])
Schönhammer, Herbert Schoenhammer.Herbert at Regensburg.de
Wed Apr 26 02:48:36 EDT 2006
The tipp from Astrid Emde is only the solution for displaying a treeConfGDE in a tab.
But the wrong behavior of treeConfGDE described from Anna S. is still observed.
The map is not repainted when layers are selected. Also the "repaint"-Button doesn't work.
Only layers with "sel_default" in "Edit gui-wms" are displayed.
Has anybody a solution for this in MB 2.2.2 ?
Or does anybody know, if this works in MB 2.2.3 ?
greetings Schönhammer Herbert
>-----Ursprüngliche Nachricht-----
>Von: Astrid Emde [mailto:astrid.emde at ccgis.de]
>Gesendet: Mittwoch, 12. April 2006 17:28
>An: users at mapbender.osgeo.org
>Betreff: Re: [Mapbender-users] document.getElementById(tab_ids[i])
>Anna S. schrieb:
>> I've tried to create a treeGDE folder using treeConfGDE in
>Mapbender 2.2.2
>> but now I've problems with displaying any layer in the mapframe. The
>> Javascipt Console reports the following error:
>> "document.getElementById(tab_ids[i]) has no properties"
>> If I try to redraw the mapframe: there comes a map, however
>the Javascipt
>> Console notifies:
>> "mb_mapObj(ind) has no properties"
>> "mb_button(ind) has no properties"
>> I've even defined some layers with "sel_default" in "Edit
>GUI-WMS". When I
>> try to check a layer directly in the treeConfGDE tool it
>doesn't work.
>Hi Anna,
>  do you use the element tabs in your gui?
>The error document.getElementById(tab_ids[i]) looks like.
>Have a look at the element vars of the element tabs (go to an
>admin gui
>- select your gui - go to edit gui elements  - klick on the
>link of the
>element tabs)
>tabs:
>  There you find the tab_ids of the elements you want to be
>part of the
>tabs. Maybe your "old" treeGDE is still mentioned in one of
>the tab_ids.
>replace it with your treeConfGDE
>Also you have to set the treeConfGDE-element hidden.
>Hope I could help
>Astrid Emde
>  Astrid Emde
>  CCGIS GbR
>  Siemensstraße 8
>  53121 Bonn
>  Germany
>          www.ccgis.de
>  Tel.:      ++49 (0) 228 90826 19
>  Fax.:      ++49 (0) 228 90826 11
>  Zentrale:  ++49 (0) 228 90826 0
>To unsubscribe, e-mail: users-unsubscribe at mapbender.osgeo.org
>For additional commands, e-mail: users-help at mapbender.osgeo.org
More information about the Mapbender_users mailing list
