AW: [Mapbender-users] new version - Mapbender release 2.4 for download (2006-07-31)
Anna Staber
staber at multimediaplan.at
Tue Aug 1 05:15:02 EDT 2006
Daniel,
I had to fix the same problem.
"MbString" is an abbreviation for Multibyte String Functions. It is required for character encoding using PHP. "MbString" is a non-default extension of PHP. So check your phpinfo().
Obviously this extension has not been installed yet and you have to do it before using Mapbender 2.4 without any troubles. On Linux the installation may work with >>yum install php-mbstring<<
For more detailed information you could have a look at http://at.php.net/mbstring (partly English/German).
Good luck!
Anna
DI (FH) Anna Staber
MULTIMEDIAPLAN.AT - DI Manfred Schrenk KEG
Technisches Bro /
Beratende Ingenieure f r Raumplanung,
Verkehrsplanung und Stadtentwicklung
Baumgasse 28
A-1030 Wien
Tel: +43 1 8928502
Fax: +43 1 8928502-15
www.multimediaplan.at
-----Ursprüngliche Nachricht-----
Von: Daniel Goetz [mailto:madprof at gmx.ch]
Gesendet: Dienstag, 1. August 2006 10:31
An: users at mapbender.osgeo.org; astrid.emde at ccgis.de
Betreff: Re: [Mapbender-users] new version - Mapbender release 2.4 for
Hi Astrid,
thank you again.
I run the "mapbender_setup.php". Everything is fine except the row concernig "MbString". It says: "MbString not installed".
But sorry for that, I don't know what the "MbString" should be. And of course I have checked out the mapbenderWiki to get to know what "MbString" means. Would you please be so kind and bring some light in my darkness? Thank you so much.
Best regards
Daniel
-------- Original-Nachricht --------
Datum: Tue, 01 Aug 2006 09:55:32 +0200
Von: Astrid Emde <astrid.emde at ccgis.de>
Betreff: Re: [Mapbender-users] new version - Mapbender release 2.4 for download (2006-07-31)
> Daniel Goetz schrieb:
> > I try to install mapbender 2.4. I wnat to load the
> "pgsql_serial_set_sequences.sql" but I don't know which one to take (the one with "7x2 or
> without it? I am using a postgreSQL database in the version 8.1.
> > Please tell me which one to take. Thank you.
> Hello,
> take the SQL pgsql_serial_set_sequences.sql. The other one is only for
> users with old postgreSQL versions.
> For more information have a look at:
> mapbender/mb_installation.txt
> and
> http://www.mapbender.org/index.php/Installation_en or
> http://www.mapbender.org/index.php/Installation_de
> Mit freundlichen Grüßen
> Astrid Emde
> Astrid Emde
> CCGIS GbR
> Siemensstraße 8
> 53121 Bonn
> Germany
> www.ccgis.de
> Tel.: ++49 (0) 228 90826 19
> Fax.: ++49 (0) 228 90826 11
> Zentrale: ++49 (0) 228 90826 0
> To unsubscribe, e-mail: users-unsubscribe at mapbender.osgeo.org
> For additional commands, e-mail: users-help at mapbender.osgeo.org
"Feel free" – 10 GB Mailbox, 100 FreeSMS/Monat ...
Jetzt GMX TopMail testen: http://www.gmx.net/de/go/topmail
More information about the Mapbender_users
