AW: [Mapbender-users] new version - Mapbender release 2.4 for
download (2006-07-31)
Daniel Goetz
madprof at gmx.ch
Tue Aug 1 05:32:54 EDT 2006
thank you Anna and Astrid for your help. I have installed this extension and now it is recognized to be installed in the mapbender_setup.php-document.
Thank you for your help.
Best regards
Daniel
-------- Original-Nachricht --------
Datum: Tue, 1 Aug 2006 11:15:02 +0200
Von: "Anna Staber" <staber at multimediaplan.at>
An: users at mapbender.osgeo.org
Betreff: AW: [Mapbender-users] new version - Mapbender release 2.4 for download (2006-07-31)
> Daniel,
> I had to fix the same problem.
> "MbString" is an abbreviation for Multibyte String Functions. It is
> required for character encoding using PHP. "MbString" is a non-default extension
> of PHP. So check your phpinfo().
> Obviously this extension has not been installed yet and you have to do it
> before using Mapbender 2.4 without any troubles. On Linux the installation
> may work with >>yum install php-mbstring<<
> For more detailed information you could have a look at
> http://at.php.net/mbstring (partly English/German).
> Good luck!
> Anna
> DI (FH) Anna Staber
> MULTIMEDIAPLAN.AT - DI Manfred Schrenk KEG
> Technisches Bro /
> Beratende Ingenieure f r Raumplanung,
> Verkehrsplanung und Stadtentwicklung
> Baumgasse 28
> A-1030 Wien
> Tel: +43 1 8928502
> Fax: +43 1 8928502-15
> www.multimediaplan.at
> -----Ursprüngliche Nachricht-----
> Von: Daniel Goetz [mailto:madprof at gmx.ch]
> Gesendet: Dienstag, 1. August 2006 10:31
> An: users at mapbender.osgeo.org; astrid.emde at ccgis.de
> Betreff: Re: [Mapbender-users] new version - Mapbender release 2.4 for
> Hi Astrid,
> thank you again.
> I run the "mapbender_setup.php". Everything is fine except the row
> concernig "MbString". It says: "MbString not installed".
> But sorry for that, I don't know what the "MbString" should be. And of
> course I have checked out the mapbenderWiki to get to know what "MbString"
> means. Would you please be so kind and bring some light in my darkness? Thank
> you so much.
> Best regards
> Daniel
> Datum: Tue, 01 Aug 2006 09:55:32 +0200
> Von: Astrid Emde <astrid.emde at ccgis.de>
> > Daniel Goetz schrieb:
> > > I try to install mapbender 2.4. I wnat to load the
> > "pgsql_serial_set_sequences.sql" but I don't know which one to take (the
> one with "7x2 or
> > without it? I am using a postgreSQL database in the version 8.1.
> > > Please tell me which one to take. Thank you.
> > Hello,
> > take the SQL pgsql_serial_set_sequences.sql. The other one is only for
> > users with old postgreSQL versions.
> > For more information have a look at:
> > mapbender/mb_installation.txt
> > and
> > http://www.mapbender.org/index.php/Installation_en or
> > http://www.mapbender.org/index.php/Installation_de
> > Mit freundlichen Grüßen
> > Astrid Emde
> > Astrid Emde
> > CCGIS GbR
> > Siemensstraße 8
> > 53121 Bonn
> > Germany
> > www.ccgis.de
> > Tel.: ++49 (0) 228 90826 19
> > Fax.: ++49 (0) 228 90826 11
> > Zentrale: ++49 (0) 228 90826 0
> > To unsubscribe, e-mail: users-unsubscribe at mapbender.osgeo.org
> > For additional commands, e-mail: users-help at mapbender.osgeo.org
> "Feel free" – 10 GB Mailbox, 100 FreeSMS/Monat ...
> Jetzt GMX TopMail testen: http://www.gmx.net/de/go/topmail
Echte DSL-Flatrate dauerhaft für 0,- Euro*. Nur noch kurze Zeit!
"Feel free" mit GMX DSL: http://www.gmx.net/de/go/dsl
More information about the Mapbender_users
