[Mapbender-users] the mapbender installation stuck on half way
smithveg smithveg at gmail.com
Thu Aug 10 07:13:03 EDT 2006
Dear,
Firstly, Thank for your reply.
The error as below in the checking database when i install the mapbender
PREPAREDSTATEMENTS =set to 'true' and php version 5.0.3 is incompatible
set PREPAREDSTATEMENTS to false or update php to >=5.1Then it prompt me the
error as below when i login
Fatal error: call to undefined function pg_prepare()
Then in the database-pgsql.php, i change the 'false' value to 'true'. Then
the Fatal Erorr was disappeared.
But i still cannot login, I think i should add a user into PostgreSQL. since
it cannot find the user. All together, did you heard about 'mapbender'
www.mapbender.org
I really urgent to fixed this in this week....
Hope you can helps me...thanks.....
I also from kl...
smith
On 8/10/06, Manfred Meier <m.meier at spiekermann.de> wrote:
> Hello,
> what system do you have and what is the problem? Do you have error
> messages? I don't know anything about postgresql but perhaps I can help.
> Manfred
> smithveg schrieb:
> > Dear, I can't get the mapbender working. I stuck on half way, anyone
> > helps me. Thanks.
> > smithveg
> To unsubscribe, e-mail: users-unsubscribe at mapbender.osgeo.org
> For additional commands, e-mail: users-help at mapbender.osgeo.org
smithveg
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20060810/da244e1c/attachment.html
More information about the Mapbender_users mailing list
