AW: [Mapbender-users] the mapbender installation stuck on half way
"Jäger, Frank \(KRZ\)" F.Jaeger at KRZ.DE
Thu Aug 10 08:41:33 EDT 2006
after setting up a new Mapbender 2.4 and loading PostgreSQL from SQL-Scripts from
   ...\resources\db\postgresql\pgsql_**.sql
... I had the same Trouble:  'root/root' was not accepted to log in.
This may be a problem how the encrypted Value is transported and loaded into PostgreSQL.
(I unzipped mapbender on Windows, export with WinSCP to Linux, where the Database and Mapbender is running)
I fixed it by writing a new Password for User "root" into the Database "mapbender":
update mb_user set mb_user_password = md5('MyNewPassword') where mb_user_name = 'root';
(from pgAdmin III Database Client)
The function md5  does the encryption. It must be defined as a function in PG.
Inserting a new user "admin1" wouldn't help you. He has no guis.
User "root" is owner off all guis.
He has to create other users.
He has do give the rights to other users.
Greetings
F. Jaeger
  _____
Von: smithveg [mailto:smithveg at gmail.com]
Gesendet: Donnerstag, 10. August 2006 13:37
An: users at mapbender.osgeo.org
Betreff: Re: [Mapbender-users] the mapbender installation stuck on half way
ya, is that, but the password has already encrypted. How can i get the password? otherwise i just add in a new user. But i do not know how to add the password. I try to use the function as below.. it cannot go though..
case 1:
postgres=# INSERT INTO mb_user VALUES(1,'admin1',password(admin),1,'admin',100);
ERROR:  column "admin" does not exist
case 2:
postgres=# INSERT INTO mb_user VALUES(1,'admin1',password('admin'),1,'admin',100
ERROR:  function password("unknown") does not exist
HINT:  No function matches the given name and argument types. You may need to ad
d explicit type casts.
This are the 2 possible error i get, when i insert new record.
On 8/10/06, Manfred Meier <m.meier at spiekermann.de> wrote:
is in the mapbender database in table mb_user (at least in my mysql
installation) a user root and a password? fields are "mb_user_name" and
"mb_user_password".
Manfred
smithveg schrieb:
> I'm using windows xp SP2, PostgreSQL (postgreSQL could support
> mapbender), PHP 5.0.3
> I did check for www.mapbender.org < http://www.mapbender.org <http://www.mapbender.org> > site, no
> solution was found. I think i stuck at admin username and password. I
> think it cannot get the default username and pasword from the
> instalation guide. In addition, i never set any password. It may be the
> default password.
> Thansk
> On 8/10/06, Lars-Hendrik Schneider <schneider at terrestris.de
> <mailto: schneider at terrestris.de <mailto:schneider at terrestris.de> >> wrote:
>     Hi <realname?>,
>     smithveg schrieb:
>      > Dear, I can't get the mapbender working. I stuck on half way, anyone
>      > helps me. Thanks.
>     I think these are to less information. Please provide what you have
>     done
>     so far, which system you use (OS, database, PHP + version, which
>     Mapbender ...) and describe in detail where you stuck. Have a look at
>     the mapbender WIKI also to get some background information. Otherwise
>     (like with this mail) it is impossible to help you!
>     Regards,
>     Lars-Hendrik
>     To unsubscribe, e-mail: users-unsubscribe at mapbender.osgeo.org
>     <mailto:users-unsubscribe at mapbender.osgeo.org >
>     For additional commands, e-mail: users-help at mapbender.osgeo.org
>     <mailto:users-help at mapbender.osgeo.org >
> smithveg
smithveg
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20060810/c377dece/attachment.html
More information about the Mapbender_users mailing list
