[Mapbender-users] where to get the map
Lars-Hendrik Schneider
schneider at terrestris.de
Fri Aug 11 05:26:17 EDT 2006
Hi
smithveg schrieb:
> Hello,
> I download a zip file form the url as below:
> http://www.cipotato.org/DIVA/data/DataServer.htm
> Inside got a GRD and GRI file. I'm not sure how to use it. Is it get the
> map and upload to mapbender?
> But you say that mapbender not display the map for user, so, who display
> the map? WMS?
Mapbender is only a client software that enabels you to get maps
(images) from specialized mapserver services. In the backend Mapbender
only (simply spoken) creates special URL requests to a program that
delivers and creates the map then. Mapbender does not create the maps
itself.
For the maps you need the data (shapes, aeral photos, TIFs ...) and a
program that takes a picture from your data and delivers it to a client
(Mapbender). Therefore you need s.th. like UMN Mapserver or ArcIMS.
So you currently just have the "remote control" for such kind of
servers. Luckily many such servers are available in the internet and can
be accessed by delivering their data in a standard format -> WMS (Web
Map Service).
There you can a file that tells Mapbender which parameters the service
expects - so that you can get maps from such a service using Mapbender
as a remote control.
Hth a bit for the background...
Lars-Hendrik
More information about the Mapbender_users
