[Mapbender-users] Usemap
Pieter Deckers
pieter.deckers at vliz.be
Tue Dec 12 06:28:02 EST 2006
Thanks Till,
the hint for unhiding the iframe was very usefull. Unless it didn't display the link I could solve the problem.
But I had to change therefore the source code. I changed line 29:
$url = urldecode($_REQUEST["url"]);
in
$url = "url"
and then it was working fine.
I don't know if this is an error in the code or a wrong setting of me.
Cheers,
Pieter
>Dear Pieter,
>first of all set the frame "usemap" in your GUI for testing purposes
>just beside your mapframe to 200px width and 200px height and set it to
>"visible" (maybe set the frameborder to "1") using edit GUi elements ->
>usemap -> width|height|style
>Reload your gui.
>If everything is ok in the new frame there should appear the link
>includig your wfs request. Copy it and throw it into another browser
>window. Your wfs should deliver objects in there, like this:
><gml:boundedBy>
>- <gml:Box srsName="epsg:31466">
>- <gml:coordinates>
>2565184.180000,5713117.700000 2591738.550000,5734990.370000
></gml:coordinates>
></gml:Box>
></gml:boundedBy>
>- <gml:featureMember>
>- <ms:sometext>
>- <gml:boundedBy>
>- <gml:coordinates>
>2586389.000000,5719736.000000 2586389.000000,5719736.000000
></gml:coordinates>
></gml:Box>
></gml:boundedBy>
>- <ms:msGeometry>
>- <gml:Point srsName="epsg:31466">
><gml:coordinates>2586389.000000,5719736.000000</gml:coordinates>
></gml:Point>
></ms:msGeometry>
><ms:bezeichnun>sometext</ms:bezeichnun>
></ms:sometext>
>If that is ok, you made a major step.
>Then ensure ,that in your php/mod_usemap.php the item which carries the
>information for the highlight flag exists in your wfs (line +/- 22)
>If your flags appear hide your usemap frame again and everything is fine.
>Till
>Pieter Deckers schrieb:
>>Hi,
>>I'm a new MapBender user. I want to add interactivity to my application
>>using 'usemap'. I've added the elements 'usemap' and 'wz_jsgraphics' but now
>>I'm stuck because I don't find more documentation. I think I'll have to
>>modify the source code of \javascripts\mod_usemap.php (1) and
>>\php\mod_usemap.php (2). I think I have to change the url in (1) on line 21
>>and in (2) on line 29 in the url of the GML-file:
>>http://192.168.0.118/cgi-bin/mapserv.exe?map=C:/data/unesco/mapfiles/unesco_
>>wfs.map&REQUEST=getFeature&VERSION=1.0.0&SERVICE=WFS&typename=Buoys.
>>But if i do this it doesn't work. Am I doing the right modification or are
>>there other parameters I'll have to change to have a good imagemap?
>>Thanks,
>>Pieter Deckers
>>To unsubscribe, e-mail: users-unsubscribe at mapbender.osgeo.org
>>For additional commands, e-mail: users-help at mapbender.osgeo.org
>* www.webmapcenter.de - Hosting *
>* GDIdevL 'Start GDI from CD' *
>* http://www.terrestris.de *
>Dipl. Geogr. Till Adams
>terrestris, H. Paulsen& T. Adams GbR
>Siemensstr. 8 * 53121 Bonn
>Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
>info at terrestris.de * http://www.terrestris.de
More information about the Mapbender_users
