AW: [Mapbender-users] MapBender 2.4rc2: Problems with loadWMC
Fischer, Andreas andreas.fischer at kreis-unna.de
Tue Jul 25 09:01:05 EDT 2006
Hello Mr. Schönhammer,
I have experienced the same you did. The same problems occur with MB 2.2.3,
the version I have in use.
I loaded the following files form the cvs and replaced the original ones:
    class_wmc.php
    mb_listWMCs.php
    mod_displayWmc.php
    mod_savewmc.php
    mod_insert WmcIntoDb.php
    map.php
I don't know, if actually all those files have to be replaced: But I got all
that are involved with WMC (e.g. includes) and now everything is working
fine. But after loading a WMC, featureInfoRequest will only work with
text/html. The database entry isn't considered. This is because of the fix
entry in class_wmc.php for text/html. Usually that won't matter, because
html-templates are nicer anyway.
Hope that helps
Greetings
Andreas Fischer
Kreis Unna
Dezernat II - Projektteam GIS
Platanenallee 16
59425 Unna
(02303) 27-2507
-----Ursprüngliche Nachricht-----
Von: "Schönhammer, Herbert" [mailto:Schoenhammer.Herbert at Regensburg.de]
Gesendet: Dienstag, 25. Juli 2006 14:04
An: users at mapbender.osgeo.org
Betreff: [Mapbender-users] MapBender 2.4rc2: Problems with loadWMC
Hi mapbender-community,
I've just installed MapBender 2.4rc2 and got some troubles with loadWMC. The
observed problems might be coupled with other reported problems concerning
loadWMC. But i'm not sure.
Using gui1 as shipped with mb2.4rc2
- Saving of a WMC does what it should do.
- Now i make some things like zooming, display other maps (WMS), do some
feautreInfo-requests.
- Now i load a WMC: after redrawing the map, the map is shown as saved with
the WMC
                               but: the treeGDE is not actualized AND
                               no further actions like displaying other WMS
or making featureInfo-requests with the treeGDE are possible
=> only the default layers (as saved with the WMC) can be displayed.
I think, interactive work with the maps should be possible, even after
loading a WMC.
Or must i configure this behaviour anywhere ?? Who knows where to configure
Thanks a lot.
Mit freundlichen Grüßen
Schönhammer Herbert
Dipl.-Ing.(FH), Dipl.-Inf.
Stadt Regensburg
Amt für Stadtentwicklung
D.-Martin-Luther-Straße 1
93047 Regensburg
Tel.: 0941 / 507-2662
Fax: 0941 / 507-4866
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20060725/679b6728/attachment.html
More information about the Mapbender_users mailing list
