[Mapbender-users] unable to login or add new user
Astrid Emde astrid.emde at ccgis.de
Tue Jun 13 08:43:02 EDT 2006
geoseom schrieb:
> I've installed mapbender 2.2.3 on an Windows XP machine toghether with
> POstgresql 8.1 (Postgis) and Xampp (PHP 5.1.1).
> Everything seems to be configured the right way, but I dont get it work.
> In the mapbender_setup.php everything is ok.
> Mapbender Setup
> Administration Database	Connect to Database	PostGIS support	md5
> PostgreSQL	on	on: VERSION 1.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1	md5 support
> When I'm calling the index.php the first time, mapbender displays the
> welcome screen, but I can't log in nor can I create a new user.
> To create the Postgresql-database i've used the SQL-scripts provided with
> mapbender. All tables exits and I have an user 'root' with the PW 'root'
> (md5-encrypted) in the table mb_user.
> The owner of the database is 'postgres' PW 'mypassword'.
this is the information ypu have to write in the mapbender.conf file.
But as the mapbender_setup.php says that everything is fine, you alredy
filled it in there
> When I try to login as 'root' or 'postgres' I end up with the login-form.
Login as root password: root
And make sure that in the mapbender.conf
define("MD5", "true");
- if you want to use encrypted password.
That should do.
Mit freundlichen Grüßen
Astrid Emde
  Astrid Emde
  CCGIS GbR
  Siemensstraße 8
  53121 Bonn
  Germany
          www.ccgis.de
  Tel.:      ++49 (0) 228 90826 19
  Fax.:      ++49 (0) 228 90826 11
  Zentrale:  ++49 (0) 228 90826 0
More information about the Mapbender_users mailing list
