unable to login or add new user
    geoseom
    g.moes at web.de
    Tue Jun 13 07:52:19 EDT 2006
I've installed mapbender 2.2.3 on an Windows XP machine toghether with
POstgresql 8.1 (Postgis) and Xampp (PHP 5.1.1).
Everything seems to be configured the right way, but I dont get it work.
In the mapbender_setup.php everything is ok.
Mapbender Setup
Administration Database	Connect to Database	PostGIS support	md5
PostgreSQL	on	on: VERSION 1.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1	md5 support
When I'm calling the index.php the first time, mapbender displays the
welcome screen, but I can't log in nor can I create a new user.
To create the Postgresql-database i've used the SQL-scripts provided with
mapbender. All tables exits and I have an user 'root' with the PW 'root'
(md5-encrypted) in the table mb_user.
The owner of the database is 'postgres' PW 'mypassword'.
When I try to login as 'root' or 'postgres' I end up with the login-form.
When I try to add a new user I get the following error-messages:
Warning: pg_exec() [function.pg-exec]: Query failed: ERROR: relation
"mb_user" does not exist in
C:\Programme\xampp\htdocs\mapbender\http\php\database-pgsql.php on line 121
Warning: pg_fetch_row() expects parameter 1 to be resource, boolean given in
C:\Programme\xampp\htdocs\mapbender\http\php\database-pgsql.php on line 289
"mb_user_mb_group" does not exist in
Warning: pg_exec() [function.pg-exec]: Query failed: ERROR: relation "gui"
does not exist in
does not exist in
does not exist in
does not exist in
does not exist in
does not exist in
Warning: pg_exec() [function.pg-exec]: Query failed: ERROR: current
transaction is aborted, commands ignored until end of transaction block in
does not exist in
does not exist in
does not exist in
does not exist in
"gui_mb_user" does not exist in
"gui_mb_group" does not exist in
_____________________________________-
How can I go on, to discover the fantastic world of mapbender????
View this message in context: http://www.nabble.com/unable-to-login-or-add-new-user-t1779825.html#a4845377
Sent from the mapbender-users forum at Nabble.com.
More information about the Mapbender_users
