[Mapbender-users] Antw: Re: Blank Map using Geoserver
Ronald Woita
sauna at justmail.de
Fri May 19 09:25:18 EDT 2006
Ronald Woita schrieb:
> Phatbloke schrieb:
>> Hi
>> I have tried but the only item in the box is EPSG:4326 the option of
>> 27700
>> is not available
>> View this message in context:
>> http://www.nabble.com/Antw%3A+Re%3A+Blank+Map+using+Geoserver-t1649246.html#a4468184
>> Sent from the mapbender-users forum at Nabble.com.
>> To unsubscribe, e-mail: users-unsubscribe at mapbender.osgeo.org
>> For additional commands, e-mail: users-help at mapbender.osgeo.org
> Hi,
> are you sure, that your geoserver offers this epsg-code in its wms
> capabilities ?
> perhaps you could post this part of the xml-document.
> best regards
> Ronald
check that the epsg-code is listed in the table 'wms_srs' for your wms.
the 'wms_id' you can get from the table 'wms'.
otherwise insert the entry manually
best regards
Ronald
Ronald Woita
www.dago0815.de
More information about the Mapbender_users
