[Mapbender-users] color of the printed temporaryobjects
Ronald Woita Ronald.Woita at rostock.de
Wed Aug 15 03:53:03 EDT 2007
thanks marc,
that is just what I'm looking for :-)
Ronald
Ronald Woita
http://geoportal.rostock.de
Hansestadt Rostock
Kataster-, Vermessungs- und Liegenschaftsamt
Holbeinplatz 14, 18069 Rostock
email: ronald.woita at rostock.de
phone: +49 (0)381 - 381 6256
>>> manns at str.de 15.08.2007 08:58 >>>
You can set the Stroke array on TRUE, to set a color.
"do_stroke" => TRUE,
"stroke_color" => array(
"r" => 254 / 255,
"g" => 1 / 255,
"b" => 1 / 255
If you don´t want to get a dashed line, you can set the dash array on line 349
like this
"dash" => array(10,0)
greets
Marc
-----Ursprüngliche Nachricht-----
Von: Ronald Woita [mailto:Ronald.Woita at rostock.de]
Gesendet: Mittwoch, 15. August 2007 08:49
An: mapbender_users at lists.osgeo.org
Betreff: [Spam:medium] Antw: Re: [Mapbender-users] color of the printed
temporaryobjects
ok, I can set the color for dashed line-
but if I change do_stroke => FALSE the result is always a thin black line.
Where can I change this ?
greets
Ronald
Ronald Woita
Hansestadt Rostock
>>> astrid.emde at wheregroup.com 15.08.2007 08:29 >>>
Ronald Woita schrieb:
> Hi all,
> where can I change the color for temporary objects in print, especial non-dashed lines ?
> greets
> Ronald
Hello,
to change the color of the temporary object go to the file
/print/mod_print_pdf_pdf.php to $theMeasureConfigArray (line 332)
If you don't want a dashed line set do_stroke => FALSE
Also have a look at
http://www.mapbender.org/index.php/Print
Best Regards
Astrid Emde
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Siemensstraße 8
 53121 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 http://www.wheregroup.com
 Amtsgericht Bonn, HRA 6788
 Komplementärin:
 WhereGroup Verwaltungs GmbH
 vertreten durch:
 Arnulf Christl, Olaf Knopp, Peter Stamm
Mapbender_users mailing list
Mapbender_users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users mailing list
