[Mapbender-users] problems with the jpl-wms
Christian.Strobl at dlr.de
Wed Aug 29 03:09:38 EDT 2007
dear mapbender users,
i have problems to integrate the following wms in mapbender applications
http://wms.jpl.nasa.gov/wms.cgi?REQUEST=GetCapabilities&SERVICE=WMS&VERS
ION=1.1.1
it doesn't work for example in the mapbender gui2 neither. the demis wms
works fine. maybe my mapbender.conf misses something (see below)
thanks for every hint
christian
p.s. also the NRW: Bodenkarte BK50 or the Bavarian WMS doesn't work, so
i think it is a elementary problem of my installation
configuration:
Mapbender 2.4.2
Php Version: 5.1.4
PostgreSQL 8.1.4
POSTGIS="1.1.2" GEOS="2.2.1-CAPI-1.0.1" PROJ="Rel. 4.4.9, 29 Oct 2004"
<?php
# $Id: mapbender.conf-dist 1425 2007-06-04 08:22:49Z christoph $ #
http://www.mapbender.org/index.php/Mapbender.conf
# Copyright (C) 2002 CCGIS
# type of mapbender database
#define("SYS_DBTYPE", "mysql");
define("SYS_DBTYPE", "pgsql");
# database information
if(SYS_DBTYPE=="mysql")
define("DBSERVER", "<HOST>");
define("PORT", "3306");
define("DB", "<database>");
define("OWNER", "<owner>");
define("PW", "<password>");
include_once("../../http/php/database-mysql.php");
# database with geos functions
define("GEOS_DBSERVER", "<HOST>");
define("GEOS_PORT", "5432");
define("GEOS_DB", "<database with geos functions>");
define("GEOS_OWNER", "<owner>");
define("GEOS_PW", "<password>");
else {
define("DBSERVER", "localhost");
define("PORT", "5432");
define("DB", "mapbender");
define("OWNER", "mapbender");
define("PW", "mapbender");
include_once("../../http/php/database-pgsql.php");
# prepared statements (PHP > 5.1.x, PostgreSQL > 7.4) #
define("PREPAREDSTATEMENTS",true);
# encoding - default characterset UTF-8 / ISO-8859-1 #
define("CHARSET","UTF-8");
# error_reporting
//ini_set('error_reporting', 'E_ALL & ~ E_NOTICE');
# directory for temporary files
define("TMPDIR", "../tmp");
# URL to login
define("LOGIN", "http://localhost/mapbender/frames/login.php");
define("MAXLOGIN", 3);
$login = LOGIN;
# URL to owsproxy
# (no terminating slash)
define("OWSPROXY", "http://<ip or name>/owsproxy");
# type of server-connection
# curl, socket, http
#define("CONNECTION", "curl");
define("CONNECTION", "http");
#define("CONNECTION", "socket");
define("CONNECTION_PROXY", "<ip>");
define("CONNECTION_PORT", "<port>");
define("CONNECTION_USER", "<user>");
define("CONNECTION_PASSWORD", "<password>");
# security: path to modules
define("CHECK", false);
# enable/disable portal
define("PORTAL", false);
# mail settings for internal mapbender mails # smtp mailing # for
further settings check 'class_administration.php'
# please check phpmailer for more information #
define("USE_PHP_MAILING", "false");
define("MAILHOST", "<host>");
define("MAILUSERNAME", "<user>");
define("MAILPASSWORD", "<password>");
define("MAILADMIN", "<mailaddress of the mailadmin>");
define("MAILADMINNAME", "<mailadminname>");
$mailHost = MAILHOST;
$mailUsername = MAILUSERNAME;
$mailPassword = MAILPASSWORD;
# wms monitoring
define("AUTO_UPDATE", "0");
define("TIME_LIMIT", "300");
define("PHP_PATH", "/usr/local/bin/");
# Mapbender error logging
define("LOG_LEVEL_LIST", "off,error,warning,notice,all");
define("LOG_LEVEL", "all"); define("LOG_JS", "on"); // "on", "alert",
"console", "off"
###HACK for GLOBALS
$DBSERVER=DBSERVER;
$DB=DB;
$OWNER=OWNER;
$PW=PW;
$GEOS_DBSERVER=GEOS_DBSERVER;
$GEOS_DB=GEOS_DB;
$GEOS_PORT =GEOS_PORT;
$GEOS_OWNER=GEOS_OWNER;
$GEOS_PW=GEOS_PW;
More information about the Mapbender_users
