AW: [Mapbender-users] problems with the jpl-wms
Christian.Strobl at dlr.de
Wed Aug 29 06:13:39 EDT 2007
hi armin,
thanks for your help but unfortunately no hint works for me (see below). do you have any further suggestions?
greetings from munich
christian
p.s. beside this i don't see anything at wms_africa, wmms_australia and so on. i think i have a principal installation problem
> -----Ursprüngliche Nachricht-----
> Von: mapbender_users-bounces at lists.osgeo.org
> [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag
> von Armin Retterath
> Gesendet: Mittwoch, 29. August 2007 09:52
> An: Mapbender User List
> Betreff: Re: [Mapbender-users] problems with the jpl-wms
> hi christian,
> You have 2 possibilities to include the service:
> loadWMS in the admin1 gui or by using the addwms module in
> the graphical guis.
> Loading the URL by using both modules doesnt make any
> problems in normal environments. Your problem is that you
> cannot ope the capabilities files with the libapache2-phpX
> module. You use http connections in your mapbender.conf file.
> Mostly its better to use the curl connection.
> Therefor you need the libcurl and php5-curl libraries. After
> installing this libraries you must restart your webserver.
the os is windows xp so there is no curl available
> If your are behind any proxy you must define this in your
> mapbender.conf! In your conf file there is no proxy defined.
> Therewy you mapbender cannot connect to the server and get
> the capabilities file.
i am behind a firewall but we are using no proxy. other wms are working well, for example the demis wms.
> Another way to register the services is to load an local xml file
> (capabilities-file) in mapbender (using the modul loadWMS in admin1).
> The file must be readable for the apache webserver! If you
> have any further questions:
> 0261/492-466
> greetings
> armin
> Am Mittwoch, den 29.08.2007, 09:09 +0200 schrieb
> Christian.Strobl at dlr.de:
> > dear mapbender users,
> > i have problems to integrate the following wms in mapbender
> applications
> http://wms.jpl.nasa.gov/wms.cgi?REQUEST=GetCapabilities&SERVIC
E=WMS&VERS
> > ION=1.1.1
> > it doesn't work for example in the mapbender gui2 neither.
> the demis wms
> > works fine. maybe my mapbender.conf misses something (see below)
> > thanks for every hint
> > christian
> > p.s. also the NRW: Bodenkarte BK50 or the Bavarian WMS
> doesn't work, so
> > i think it is a elementary problem of my installation
> > configuration:
> > Mapbender 2.4.2
> > Php Version: 5.1.4
> > PostgreSQL 8.1.4
> > POSTGIS="1.1.2" GEOS="2.2.1-CAPI-1.0.1" PROJ="Rel. 4.4.9,
> 29 Oct 2004"
> > <?php
> > # $Id: mapbender.conf-dist 1425 2007-06-04 08:22:49Z christoph $ #
> > http://www.mapbender.org/index.php/Mapbender.conf
> > # Copyright (C) 2002 CCGIS
> > # type of mapbender database
> > #define("SYS_DBTYPE", "mysql");
> > define("SYS_DBTYPE", "pgsql");
> > # database information
> > if(SYS_DBTYPE=="mysql")
> > define("DBSERVER", "<HOST>");
> > define("PORT", "3306");
> > define("DB", "<database>");
> > define("OWNER", "<owner>");
> > define("PW", "<password>");
> > include_once("../../http/php/database-mysql.php");
> > # database with geos functions
> > define("GEOS_DBSERVER", "<HOST>");
> > define("GEOS_PORT", "5432");
> > define("GEOS_DB", "<database with geos functions>");
> > define("GEOS_OWNER", "<owner>");
> > define("GEOS_PW", "<password>");
> > else {
> > define("DBSERVER", "localhost");
> > define("PORT", "5432");
> > define("DB", "mapbender");
> > define("OWNER", "mapbender");
> > define("PW", "mapbender");
> > include_once("../../http/php/database-pgsql.php");
> > # prepared statements (PHP > 5.1.x, PostgreSQL > 7.4) #
> > define("PREPAREDSTATEMENTS",true);
> > # encoding - default characterset UTF-8 / ISO-8859-1 #
> > define("CHARSET","UTF-8");
> > # error_reporting
> > //ini_set('error_reporting', 'E_ALL & ~ E_NOTICE');
> > # directory for temporary files
> > define("TMPDIR", "../tmp");
> > # URL to login
> > define("LOGIN", "http://localhost/mapbender/frames/login.php");
> > define("MAXLOGIN", 3);
> > $login = LOGIN;
> > # URL to owsproxy
> > # (no terminating slash)
> > define("OWSPROXY", "http://<ip or name>/owsproxy");
> > # type of server-connection
> > # curl, socket, http
> > #define("CONNECTION", "curl");
> > define("CONNECTION", "http");
> > #define("CONNECTION", "socket");
> > define("CONNECTION_PROXY", "<ip>");
> > define("CONNECTION_PORT", "<port>");
> > define("CONNECTION_USER", "<user>");
> > define("CONNECTION_PASSWORD", "<password>");
> > # security: path to modules
> > define("CHECK", false);
> > # enable/disable portal
> > define("PORTAL", false);
> > # mail settings for internal mapbender mails # smtp mailing # for
> > further settings check 'class_administration.php'
> > # please check phpmailer for more information #
> > define("USE_PHP_MAILING", "false");
> > define("MAILHOST", "<host>");
> > define("MAILUSERNAME", "<user>");
> > define("MAILPASSWORD", "<password>");
> > define("MAILADMIN", "<mailaddress of the mailadmin>");
> > define("MAILADMINNAME", "<mailadminname>");
> > $mailHost = MAILHOST;
> > $mailUsername = MAILUSERNAME;
> > $mailPassword = MAILPASSWORD;
> > # wms monitoring
> > define("AUTO_UPDATE", "0");
> > define("TIME_LIMIT", "300");
> > define("PHP_PATH", "/usr/local/bin/");
> > # Mapbender error logging
> > define("LOG_LEVEL_LIST", "off,error,warning,notice,all");
> > define("LOG_LEVEL", "all"); define("LOG_JS", "on"); //
> "on", "alert",
> > "console", "off"
> > ###HACK for GLOBALS
> > $DBSERVER=DBSERVER;
> > $DB=DB;
> > $OWNER=OWNER;
> > $PW=PW;
> > $GEOS_DBSERVER=GEOS_DBSERVER;
> > $GEOS_DB=GEOS_DB;
> > $GEOS_PORT =GEOS_PORT;
> > $GEOS_OWNER=GEOS_OWNER;
> > $GEOS_PW=GEOS_PW;
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Armin Retterath
> Kompetenz- und Geschäftsstelle
> Geodateninfrastruktur Rheinland-Pfalz
> beim LVermGeo-RP
> Ferdinand-Sauerbruch-Straße 15
> 56073 Koblenz
> Telefon: +49 (0)261/492-466
> Fax: +49 (0)261/492-492
> E-Mail: armin.retterath at lvermgeo.rlp.de
> http://www.geoportal.rlp.de
More information about the Mapbender_users
