[Mapbender-users] problem with wfs conf
Christian.Strobl at dlr.de
Wed Aug 29 11:56:56 EDT 2007
hi mapbender users,
i have the next problem. if i want to configure a wfs (geoserver), i get
the following error message:
Warning: pg_exec() [function.pg-exec]: Query failed: ERROR: syntax error
at or near ";" at character 77 in
C:\Programme\mapbender\mapbender_2.4.2\mapbender_2.4.2\http\php\database
-pgsql.php on line 133
Warning: pg_exec() [function.pg-exec]: Query failed: ERROR: operator
does not exist: integer <> HINT: No operator matches the given name and
argument type(s). You may need to add explicit type casts. in
my configuration:
Mapbender 2.4.2
Php Version: 5.1.4
PostgreSQL 8.1.4
POSTGIS="1.1.2" GEOS="2.2.1-CAPI-1.0.1" PROJ="Rel. 4.4.9, 29 Oct 2004"
thanks for your help
christian
p.s. the load wfs operation worked successfully
More information about the Mapbender_users
